Disclaimer: There's a lot of people recommending to do this mod, but I haven't seen any idiotproof guides on how to do it. I'm not saying this is the best way to do this mod, it's just how i've done it - and hopefully this will help others, even if they don't follow my way 100%.
Brief overview: The general consensus is that from Factory, M35 Stageas limit throttle to 30% for up to 3 seconds after releasing the brake pedal. This can prevent good launches/coming out of corners faster. By cutting the signal wire to the ECU, we can maintain full throttle immediately after releasing the brake. It is OK to cut this wire, however you will get a Check Engine Light after some time. By rigging it up to a switch, you are able to disable/enable the mod freely.
  1. Behind the glovebox is the ECU. You will need to dissemble the passenger side interior to access this, there's other guides online on how to do this - so I will assume you have your glovebox out and are looking at the ECU.
  2. Pull the plastic off guard off the ECU connector, it clicks off the 4 tabs on each corner.
  3. Find the VIOLET wire with the BLUE stripe - you can see it in pictures 1 + 4 of this post. I cut this wire, and attached either side to a terminal block. You can pick these up from JayCar very cheaply - I used a terminal block because I don't trust myself to solder wires coming directly off the ECU.
  4. I then picked up a small, discrete ON/OFF toggle switch (also from JayCar), which I mounted in my Glovebox - see pictures 2 + 3. Lastly just attach these wires to the remaining spots on the terminal block.
  5. Test the switch while everything is apart - This way you can fix any problems before reassembling.
  6. Done!
Picture 4 of this post explains the above if anyone is unclear.
Some people have hooked this up to the reverse switch in the car, so they don't have to touch the switch ever - however I like the idea of a toggle, so I can limit throttle power when a family member/friend drives the car.
  • Like 2
https://www.sau.com.au/forums/topic/460199-m35-brake-switch-cutoff-mod/
I like it but it's going to be a bit of a stretch to flick the switch when you are driving.
Definitely - Although I think of it more as a valet switch, however. When I drive the car I leave it enabled, if I take the car to a mechanic or lend to a friend I will disable the switch.
Can also disable the mod to clear any CEL that appears. You could mount the switch wherever you like, though - It's just where I put it :)
Agreed.
Mine is a latching switch down next to my right knee; push it in, hold down brake lightly for 5 sec, push switch again to release; good to go for another week or more.
The only Violet with a white line wire I can see is the engine revs to Hicas ecu wire.
Can you take a pic of the back of the plug?
Edit, I just noticed it looks like the correct wire at the top, but the one you pointed to is not actually connected to the switch? or is it just the pic. Looks pink/white.
Never mind, I must be tired. :P
Yeah got it from the below threads haha - It's definitely the right wire, my colour perception just isn't very good lol.
Now that I'm running a MAP sensor I can do cool stuff like video what this brake mod actually does. Enjoy.
Matt
Nice videos, can clearly see what this mod does.
Edited by DrLui
  • Like 1
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
