M35 Brake Switch Cutoff Mod
Disclaimer: There's a lot of people recommending to do this mod, but I haven't seen any idiotproof guides on how to do it. I'm not saying this is the best way to do this mod, it's just how i've done it - and hopefully this will help others, even if they don't follow my way 100%.
Brief overview: The general consensus is that from Factory, M35 Stageas limit throttle to 30% for up to 3 seconds after releasing the brake pedal. This can prevent good launches/coming out of corners faster. By cutting the signal wire to the ECU, we can maintain full throttle immediately after releasing the brake. It is OK to cut this wire, however you will get a Check Engine Light after some time. By rigging it up to a switch, you are able to disable/enable the mod freely.
  1. Behind the glovebox is the ECU. You will need to dissemble the passenger side interior to access this, there's other guides online on how to do this - so I will assume you have your glovebox out and are looking at the ECU.
  2. Pull the plastic off guard off the ECU connector, it clicks off the 4 tabs on each corner.
  3. Find the VIOLET wire with the BLUE stripe - you can see it in pictures 1 + 4 of this post. I cut this wire, and attached either side to a terminal block. You can pick these up from JayCar very cheaply - I used a terminal block because I don't trust myself to solder wires coming directly off the ECU.
  4. I then picked up a small, discrete ON/OFF toggle switch (also from JayCar), which I mounted in my Glovebox - see pictures 2 + 3. Lastly just attach these wires to the remaining spots on the terminal block.
  5. Test the switch while everything is apart - This way you can fix any problems before reassembling.
  6. Done!
Picture 4 of this post explains the above if anyone is unclear.
Some people have hooked this up to the reverse switch in the car, so they don't have to touch the switch ever - however I like the idea of a toggle, so I can limit throttle power when a family member/friend drives the car.
  • Like 2
I like it but it's going to be a bit of a stretch to flick the switch when you are driving.
Definitely - Although I think of it more as a valet switch, however. When I drive the car I leave it enabled, if I take the car to a mechanic or lend to a friend I will disable the switch.
Can also disable the mod to clear any CEL that appears. You could mount the switch wherever you like, though - It's just where I put it :)
Agreed.
Mine is a latching switch down next to my right knee; push it in, hold down brake lightly for 5 sec, push switch again to release; good to go for another week or more.
The only Violet with a white line wire I can see is the engine revs to Hicas ecu wire.
Can you take a pic of the back of the plug?
Edit, I just noticed it looks like the correct wire at the top, but the one you pointed to is not actually connected to the switch? or is it just the pic. Looks pink/white.
Never mind, I must be tired. :P
Yeah got it from the below threads haha - It's definitely the right wire, my colour perception just isn't very good lol.
Now that I'm running a MAP sensor I can do cool stuff like video what this brake mod actually does. Enjoy.
Matt
Nice videos, can clearly see what this mod does.
Edited by DrLui
  • Like 1
 Share
    • I did a pretty ruthless clean up before I left townsville. If it wasn't a part to suit a car I currently have it was sold or binned. I have all my stuff organised in big tubs with lids that stack from supercheap and bunnings depending on who was cheaper at the time. Parts were sorted by either chasis/motor/Fabrication/general/electrical. I have a mezzanine that's 7mx2.3m and all lives up there. Easy to access when needed and out of the way.  I also have the issue of selling and dealing with scumplace/marketbook was actually going to list stuff today but couldn't be bothered as been stuffed around too much. I generally let a few people know I want to off load stuff and people pass it on to others to contact me, generally easy sale and I'm never looking to make big dollars. Rather it gets used than go in the bin. Next clean up will be around Xmas and if doesn't go on the s15 it's going bar 2 sets of wheels.
    • Did a little bit on the V37 today. I bought this LED kit out of the US https://www.ebay.com.au/itm/125953603618. Best I could find online but didn't look great, in the end the quality was pretty much right and it did come with locations for each light including rear number plate and a few spares. The factory owners' manual was also useful with information on where to pop each light out without damage. I prefer the LED look as I use it daily including at night and the LEDs are both brighter and the white light is easier to read with. Vanity mirror comparison, LEDs just look more modern The glove box was the only difficult one (and the only one that was previously blown.....), steps were Open glovebox 50% but not fully open Push up on bottom of the box to unclip it on both side, not screws or pins to remove Remove the top stays at an angle, right side then left, because.... Before dropping the glovebox totally, remove soft close clip on left Then, remove 7 screws to release the glovebox surround Twist the globe holder anti clock to release it from the surround In this case, the LED globe supplied was wider than factory and did not fit, so I ground down each side about 1mm then inserted it Last trick, start engine to check the LED polarity is correct, the globe only operates when the engine is running (whether the box is open or closed) I also moved the 4G booster and wifi across from the Fuga, a little frustrating as I could not find a good Accessories ACC source anywhere in the boot so I'll run a wire from the cabin next time I get a chance. Also, unlike the Fuga the external antenna wire does not quite fit between the rear windscreen and the body so I think I'll have to drill a hole in the roof to mount it. Probably not that interesting for most people so I'll just post once complete
    • Pretty sure I could do but it would need to be exported and reimported as the current import approval is race only. But in practice there are plenty of other practical reasons it can't be a road car despite their potential value these days like stripped interior looms, cage to cut out etc Nah, no mods to it other than updating the roll age to current regs. It makes about 350 (laggy) kilowatts on the N1s at 18psi which is enough to push it around the place
    • This is it, folks! Our final event of the year... The big one, you all know and love - Putty Road! It goes without saying, but this is the biggest cruise in our calendar each year! A nice long drive, with a hearty pub feed at the end! Do you need much more enticing than that!?!? So make sure you wash the car, get your cameras out, block out the calendar, and get ready! We know you're all as excited as we are, so make sure you lock in the details and date below: Date: Sunday 8th December 2024 Meet Location: Corner Windsor Road and Groves Avenue McDonald's / KFC (3 Groves Avenue, Mulgrave) Meet Time: Meet at 9:00am for a 9:30am departure Destination: The Royal Hotel, Singleton (84 George St, Singleton) Map: https://tinyurl.com/saunsw-puttyrd Itinerary: We will meet at McDonald's / KFC on Windsor road and from there will head onto Putty Road. There will be a break at the Grey Gum Cafe (8679 Putty Rd, Putty) which we should reach at approximately 11:30am. For all the Newcastle folks this will be a good point to join up. From here we will continue on to Singleton for lunch. Please remember to fill up prior to heading onto Putty Road. There will not be a fuel stop until Singleton. To those running on E85, Freedom Fuel (old United) at Vineyard on Windsor Road has started selling there. At Singleton there is a range of servo's available including BP, Shell and Caltex. There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Back by popular demand - we're lining up another Old Pac Run! Get your cars ready for one of the best night runs on the calendar! So without any ado whatsoever, here are the details for you to save: Date: Saturday 23rd November 2024 Meet Location: Cowan Truck Stop (Pacific Motorway - Refer to Map) Meet Time: Meet at 7:30pm for a 8:00pm departure Destination: Gosford McDonald's (65 Pacific Highway, Gosford West) Map: https://tinyurl.com/saunsw-oldpac Definitely an easy one for this cruise, meet at Cowan Truck Stop and jump straight onto Old Pacific Highway! Final stop at McDonald's which has plenty of parking all around. Please be mindful of the added police presence lately so best behaviour is expected! There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAU:NSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
