That's the thing. I can't test drive any of this stuff locally. It's a day trip to Melbourne or Sydney everytime, and when we have a toddler wasting a day like that - when I'm not even touching my track car, goes down really well...
Personally bang for buck the sti has it down pat at the moment and don't be so fast to write them off as an option until you actually drive one, I always looked down on wrxs then one came up cheap and I needed a car so I bought it. Turns out I love them, I even upgraded to an Sti 9 months later (took my time to find the right one) and it's an absolute blast. The Gtr has even been on the back burner for a bit cause I'm enjoying the Sti to much
I couldn't do it. After reading something about them intentionally putting non tuned length manifolds on their cars for the distinct purpose of providing a unique exhaust sound at the expense of torque, revs, and known issue with cylinder temps doesn't sit right.
Sure companies make mistakes, look at crank changes from 32 onward, but if you know it's shit, do something about it, don't try and tell people it's not shit.
I realise you can just bang different manifolds on, but for me there's nothing redeeming about a Subaru that you can't get in an Evo with an arguably stronger engine.
Not saying they can't last, but my guess would be a 4G would last longer with higher levels of punishment than any EJ.
I can also say from personal experience that every WRX I've seen with similar power and tyres to my CA powered Silvia is substantially slower around a track and I'm not exactly Peter Brock.
They made a name for themselves in Rally, I can appreciate that. That's where my appreciation stops.
</rant> lol
time for a family trip to a major city i think.
i'm going through the motions of deciding what car would suit my own needs, should i need/want one later on and feel like there are just too many options.
although i'd be personally happy with a 34 that had guts 2.8, single etc
but the missus would want something auto and comfy
meet her half way with brides and a sequential i think.
  • Like 1
Bang for buck and capability wise - even features in some instances being a newer car - they win, but they don't have the road presence if that's a "thing".
Feels like a younger mans car than I should be driving.
Edited by ActionDan
2009/10 335i with a JB4 is well worth looking at
Value for money at around 35k
300kws, style, presence and some luxury :D
Edited by Sinista32
some good resposnes here.
before buying the GTR i did want to buy a Blue Meanie mock up. sort of wish i did considering how they have now skyrocketed in price in the last 12 months!
personally ive always had imports after after driving a stockish 308 it was a real piece of poo. still love the VK shape/ styling. ofcourse, it would have to be blue, 19" aeros, scheel trim lol.
Wanted the gtr since i was a kid and ended up jumping on that instead!
the JB4 is plugin to the existing ECU which gives the extra 100hp (75kws)
Safer than houses :thumbsup:
Look for the light blue one FS in Canberra. 81,000kms. $37,900 neg.
Edited by Sinista32
Yeah Sorry.
But don't let that put you off unless you wish to track.
Metal Panel shifts up/down on both sides.
One owner and meticulously taken care of. Took it for a drive a month ago.
I offered 35k as he wanted 40k and had just reduced from 43k.
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
