Motor has blown on my 32 GTR, will be selling the rolling shell after i've parted it out. Its registered and engineered with a single turbo, coilovers etc.
Will be putting up prices and i'd like to confirm some parts sold before i go ahead. Namely the turbo kit. Looking for expressions of interest here regarding the following....
Turbo kit will not be separated, just passed pits inspection in WA
Consists of;
Precision 6262 plain bearing .82 rear
Genuine HKS manifold with EGT bungs on each runner, V band to turbo from a T51R kit
Genuine HKS 60mm wastegate
4'' ally intake with -12 breather fitting & air filter
3'' dump vband & front pipe twin 02 sensors
2.5'' wastegate plumb back pipe vband
-12 drain speedflow fittings, braided oil feed line
Ally turbo to intercooler piping
Complete kit bolted on my car right now, everything near new, bolt onto yours tune away you go
Made 465rwhp on 18psi bp98
$5500 open to reasonable offers, rather sell locally due to size but will ship at your expense
https://www.sau.com.au/forums/topic/460223-wa-r32-gtr-rb26-precision-turbo-kit/
Still available. Looking at offers over 5k this week
Don't be tricked purchasing an incomplete kit then spending thousands to make it fit... I've done the time consuming work and money spending for you :)
Oh and i didn't mention this turbo kit will do 700+ rwhp / 500+rwkw on E85
Hi, What sort of money you will be looking for the whole car less engine and turbo?
I have got 2 RB 26 that I can make it into a running car again
Alex
GTR Workshop Braeside 3195 0433878905
  • 3 weeks later...
  • 2 months later...
Turbo kit sold
Still got the rego'd & engineered roller. Missing turbo kit as per above, needs fuel system (reg, injectors & pump), koyo damaged, need shroud, rad pipes, coilpacks, ecu rest is there. Looking at offers round 10 - 11k
Also for punters.. The roller has forged motor *broken but running* (needs strip down and inspection), carbonetics (exedy) twin plate clutch (5000km old) tein flex coilovers & edfc, 320km/h cluster, momo wheel, cusco caster arms, stereo, full interior etc
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
