well, say if he plans to put in a proper diff, a sequential box, a dirty 30, full brembos all round.... then no real diff if it's GTS-t OR GTS... actually he benefits... doesn't have that homo HICAS subframe
How much would I be looking at roughly to do an engine swap? + upgrading brakes etc?
Thanks to all those who actually replied maturely by the way! I've only just bought this car so I would love to build it up and get to learn things along the way.
& no I shouldn't have just bought a project car than because I just returned to Australia after living in Europe for a couple of years.
In the mean time instead of a turbo, is there really any other way to give the car a bit more power? The car has a K&N pod filter, heavy duty clutch, 3.5inch catback exhaust (which is way too loud) + a lot more I can't remember atm!
Rough figures?
Engine 1.5k
Gearbox 1k
Diff 300
Brakes 300
Hubs 300
Other stuff, eg intercooler fuel pump extra bits involved that everyone forgets 500-1000
So 4-4.5k.
Selling your gts and buying a gtst will not cost you that much
Rough figures?
Engine 1.5k
Gearbox 1k
Diff 300
Brakes 300
Hubs 300
So 4-4.5k.
Thanks for that man! Seems like selling and buying a gtst is the best way to go about it, cheers!
Or do you just enjoy being a dickhead throughout the day on the internet?
well in fairness, we ALL enjoy doing that, I know I certainly do.
Ben I can't believe you didn't say NOSSSSSS!!
but seriously you could mess about with little mods but by comparison to going turbo, not a lot that will give you dollar-value HP.
There is a lot cynicism in this forum on the topic of N/A power-ups, probably due to the number of young(ish) guys who have just bought an N/A Skyline and then come on this forum looking for a cheap power-up. They nearly always seem to think there is a magic solution that we all know but have chosen to keep secret. Sadly, there is no magic :-(
My axiom when it comes to modifying cars, learned through hard experience is:
Performance, reliable, inexpensive ... pick any one-and-a-half.
It is best to gather enough resources (ie knowledge, experience, parts/money) to do it once and do it right. Any other way will lead to much sadness.
Curb your natural enthusiasm, enjoy what you have got, and research the possible mods to make it better..
One day you too will have a mega Skyline like the rest of us, which makes your friends envious and which gets your girlfriend/boyfriend/farm-animal all hot and bothered (hey, I'm not judging), and life will be good. Dinks!
Edited by david.r34.gtt
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
