well, say if he plans to put in a proper diff, a sequential box, a dirty 30, full brembos all round.... then no real diff if it's GTS-t OR GTS... actually he benefits... doesn't have that homo HICAS subframe
How much would I be looking at roughly to do an engine swap? + upgrading brakes etc?
Thanks to all those who actually replied maturely by the way! I've only just bought this car so I would love to build it up and get to learn things along the way.
& no I shouldn't have just bought a project car than because I just returned to Australia after living in Europe for a couple of years.
In the mean time instead of a turbo, is there really any other way to give the car a bit more power? The car has a K&N pod filter, heavy duty clutch, 3.5inch catback exhaust (which is way too loud) + a lot more I can't remember atm!
Rough figures?
Engine 1.5k
Gearbox 1k
Diff 300
Brakes 300
Hubs 300
Other stuff, eg intercooler fuel pump extra bits involved that everyone forgets 500-1000
So 4-4.5k.
Selling your gts and buying a gtst will not cost you that much
Rough figures?
Engine 1.5k
Gearbox 1k
Diff 300
Brakes 300
Hubs 300
So 4-4.5k.
Thanks for that man! Seems like selling and buying a gtst is the best way to go about it, cheers!
Or do you just enjoy being a dickhead throughout the day on the internet?
well in fairness, we ALL enjoy doing that, I know I certainly do.
Ben I can't believe you didn't say NOSSSSSS!!
but seriously you could mess about with little mods but by comparison to going turbo, not a lot that will give you dollar-value HP.
There is a lot cynicism in this forum on the topic of N/A power-ups, probably due to the number of young(ish) guys who have just bought an N/A Skyline and then come on this forum looking for a cheap power-up. They nearly always seem to think there is a magic solution that we all know but have chosen to keep secret. Sadly, there is no magic :-(
My axiom when it comes to modifying cars, learned through hard experience is:
Performance, reliable, inexpensive ... pick any one-and-a-half.
It is best to gather enough resources (ie knowledge, experience, parts/money) to do it once and do it right. Any other way will lead to much sadness.
Curb your natural enthusiasm, enjoy what you have got, and research the possible mods to make it better..
One day you too will have a mega Skyline like the rest of us, which makes your friends envious and which gets your girlfriend/boyfriend/farm-animal all hot and bothered (hey, I'm not judging), and life will be good. Dinks!
Edited by david.r34.gtt
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
