I am wondering if anyone has any input on going to 3.9s i currently have 4.3 and love the acceleration of it but i thing its better suited with 4.11 or 3.9 which i have both of but cant decide what would be better hopefully someone has some facts that can help me decide.
the car will be used in circuit and 1/4 mile plus 1000 meter runs.
any input would be appreciated as i will be doing it this week.
If you have the data for your existing 4.3 diff you can directly calculate the change points for your car with 4.11 or 3.9 and choose what's best for dragging. A taller ratio will reduce wheelspin but increase the distance between gears so it rather depends on the power band of your car and the nature of the circuits.
Diff ------ 3rd ----- 4th ------ 5th km/h
4.35. ---- 147.13 ---- 191.57 ---- 254.74
4.11. ---- 155.72 ---- 202.75 ---- 269.62
4.08. ---- 156.87 ---- 204.24 ---- 271.60
3.9. ---- 164.11 ---- 213.67. ---- 284.14
3.69. ---- 173.45 ---- 225.85 ---- 300.31
At 7000rpm
This with wheel size 255/35/18
Im just not to sure what would work better as a over all package.
Wheel spin has stop thanks to the new federal 595 rs rr tyres
Edited by WARLORD
well 400m should be easy enough to decide, but for circuit use it will depend which tracks you go to, and how you find those ratios at the moment.
Personally I prefer the shorter gears because in NSW we don't have tracks like Sandown or Phillip Island where you are in danger of hitting the rev limit in 5th
If your main interest is drag and track the decision would seem simple - if 255 km/hr top speed is enough stick with what you have. If not pick the ratio that gives you the top speed that you require. The shorter diff gives you closer ratios (and I believe Duncan runs the 4.3s).
If you are a serious circuit racer and have some fast tracks as well as slower ones you could consider changing diffs to suit the track!
The main reason I like taller diffs is for comfortable road cruising.
yeah sorry I've got no idea on 1000m either, although there are others on here who do that. In both 400 and 1000 I would guess that the shortest gearing that doesn't require an extra gear change is the quickest, which is how I read what XKALABA was saying
and yes I run 4.375 in the race car, its one of the few mods allowed. a bit like 400m there is a trade off between acceleration from shorter gears vs extra gear changes in corners.....I generally prefer a higher gear and midrange out of corners than screaming out sideways in a lower gear so shorter gears suit me. But that is only general, each track and lap time would be different
That much ?
Wow with 11psi limit I would have pegged it around 210-220kw
There are a few reasons I say don't use 5th,
1) the time it takes to select 5th is time the car isn't accelerating
2) 5th gear isn't overly strong and shouldn't be used for racing unless necessary, like 1000m runs
3) 5th is an overdrive gear and defeats the purpose of using a shorter diff ratio
With Duncans car only having 240 or so kw on semis and 4wd he isn't really going to have many issues fighting traction but with 390rwkw and only RWD the shorter ratio will see alot of wheel spin through the first few gears
My R34 with about 420awkw and the factory 3.545 diff and the stock Getrag 6 speed it will spin all of 1st all of 2nd and most of 3rd with 295 semis :D
I have since changed that to a option 2 OS88 with a much taller 1st and moded transfer case and on 19psi (380kw) at Coota for Nulon Nationals it pulled away nicely, watch the Nulon Nationals round 4 2015 vid on YouTube I'm the only blue 34 and only did one pass
https://m.youtube.com/watch?v=rmxbttyMoJo&feature=youtu.be
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
