So i had a go at bolting a neo head down onto the RB30 bottom and theres couple of possible issues which im not 100% sure if will be a problem..
so brief run down
- sprayed copper spray on the headgasket but didnt torque it down for about 2hrs but it was installed with head sitting on it.
- kept getting a few oil drops leaking out the drains in the head so maybe have leaked a bit onto the head gasket on one side.
- torqued it down in 3 steps 25nm, 50nm, 80nm
So is this dodgey or all good?
https://www.sau.com.au/forums/topic/460354-head-gasket-install/
its all good, i took the head back off few hours ago and looks like it was gonna leak cause around those drain holes it was bit oily and clean so the gasket there had not stuck to the block and head like everywhere else.... :/
Was using a OEM RB26 gasket, but i just purchased a RB30 OEM gasket to try again..
Have used copper spray on an LS1 and an ecotec with success so i guess just following that run of successes, the copper must mix into the gasket cause i cant see much copper after taking the gasket off, was mostly sealing though cause i couldnt get the head back off without prying it with a bar...
Edited by AngryRB
Have to make sure the oil doesn't drip down onto the gasket thought while im trying to fit and torque it down, thinking of washing the head with diesel and blowing out with compressed air, hopefully that will work....
Is Hylomar Spray the best thing to use?
I use copper spray on copper head gaskets, torque down when tacky.
Hylomar when reusing a old MLS of if the heads not skimmed.
New MLS gets nothing on a skimmed head.
No oil, everything to be spotlessly clean, if you have oil leaking out of the head clean it out first with a air compressor blower.
biggest problem at the moment is an endless drip, shouldn't be this hard to bolt a head down... lol..
I used some plasti guage to check the head and block are straight and all good but when lifting head back off there was a good film of oil left after blowing it all passages with compressed air etc.. so its playing games with me .. must be some hidden oil gallery/drain in the center that has a pool, kind of like a spring in the ground lol... :rant:
On a positve note though, the gasket and copper spray had stuck to the head and block pretty well, took ages to clean block and head apart from the bit round these gallaries..
Edited by AngryRB
discovered that one washer is unaccounted for, worst feeling cause if its in the head somewhere its not showing itself, i've used a magnet on the end of a tube , blow compressed air , turn it upside down and search everywhere but its either not there or its hiding lower in the head???
Must be some kind of hidden chamber in the middle of the head?? can i pull the large welsh plugs out from the rear and front and gain access from there to rule this out..??? :ermm:
Edited by AngryRB
  • Like 1
Dude I had a similar problem... The washers fell down into the valve Spring seat and they are a bitch to get out... You need one of them inspection cameras to find out if it's fallen in there! I would not risk it because I reckon it will f**k your shit up...
  • Like 1
yeah i think ill try to get one of those camera's, the washer is a decent size, id say about 18mm diameter
how many times can you remove an ARP stud and tension them back up, done it twice now :ermm:
The more times the better as long as the studs never been overtightened. (therefore over stressed and weakened)
Each time you wear the nut and washer it smooths it out better, however if using ARP lube it makes not much difference as its that good as a lubricant.
Pulled the large welsh plug off the back of the head, thats just for coolant so thats no good, am looking at the inspection camera's but wondering if they will be able to get down into the lower drain holes before i spend $$
Does anyone know if you can use this camera to look into the head from under the block with the sump off? Engine builder says it will flush out to the sump and not to worry bout it but wanna make sure..
http://www.ebay.com.au/itm/Genuine-Autel-MV400-8-5mm-Car-Digital-Borescope-Videoscope-Inspection-Camera/251177013261?_trksid=p2141725.c100338.m3726&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20150313114020%26meid%3Dd6257c12f3fd49f7b5d3af24c973cbe0%26pid%3D100338%26rk%3D3%26rkt%3D8%26sd%3D290842847189
Edited by AngryRB
looks like im on my own here, thanks for all above help, we'll see if she blows on the dyno, all thanks will go to sau lol......
will try tilting it on an angle with the engine hoist and flushing/compressed air to see if a washer comes out or not, apart from that its all a toss of the coin... stay tuned or not... :starwars:
  • Like 1
Good luck with it!
    • Nope, still smaller rear, put on the 4inch exhaust and picked up power everywhere, ended up just shy of 800rwhp.   Didn't seem to be hitting any walls either, so perhaps could have pushed for more but all maybes and the fish that got away etc etc.
    • Races cars don't care for VIN either...
    • This could be sold and shipped to the US for many gold pieces. RMS has no say in that. Ask various Western Sydney inhabitants how it works.
    • Ha ha ha, mine loves to spend, all on the dogs (they're our kids, and her spending would likely rival that of some people raising children!) the only benefit is, her spending is tax deductible as she runs a business in the dog industry 😛 The above all means she can spend race car budget quicker than I can. 😛 That and a lot of the things I want are very expensive, and I can be a bit "you want how much for that?!" And at other times overly impulsive. Or I start the w days of research, get to day 1.5 and get really annoyed that no one will advertise actual specifics and it's just marketting BS and I go "well, now I don't want anything to do with that now!" Also I hate paying lots of money for something I can make from $50 in materials. Then I get the shits halfway through making things and wonder why others who just buy parts have more fun... 😛
    • Their 240Z with the RB26 would be a real nice thing to have in a garage to come out for an occasional weekend cruise It's such a cool thing in so many ways Sadly, we have a blue 240Z shell that I walk past every day, just sitting outside a shed at work, it has been slowly disintegrating and falling apart into the ground for the last few years, the owner cannot be found, and I am unable to "claim it" I've been told by work and the RMS, the rust in the body is excessive though, and it has had most of the salvageable stuff, like panels, trim and switch gear stripped off it over the last year or two, work keeps threatening to put it in one of our metal scrap bins, I wish they did though, as it makes Mark sad walking past it
