hey guys
the times come to sell my daily.
had it for a few months, just isnt for me.
2006 E60 525I m sport
115thou kays
jam packed with features
heads up display
full cream leather
sunroof
electric seats
sat nav
TV
pretty awesome standard sound system
AIRCON!
CUPHOLDERS!
6 speed auto
18" alloy wheels
M sport bodykit
some kind of cool looking roof wing and boot lip
the bad:
has a dent and scrape on the rear ds quarter.
the car required a new steering wheel position sensor. this doesnt affect the driving anyhow so i never bothered to change it.
one air pressure sensor in the tyre is loose so gives some false readings sometimes
car will come with 12 months rego, a valid RWC and have a Interior and exterior detail when sold.
$25,000 neg, partially open to swaps.
once again, id love to keep this car but it just isnt for me, and also have a holiday to pay for.
who ever buys this will not be dissapointed, have never seen one in this colour before.
Mohsen.
pictures coming soon
  • 1 month later...
  • 1 month later...
  • 3 months later...
Steering angle sensor repaired- no errors.
Going in to have the bonnet painted and rear quarter repaired next week.
Price to go up.
Can supply with rwc for the right price.
  • 3 weeks later...
  • 1 month later...
Would you swap for a RB28 turbo sedan with a violent amount of cash in the other direction (assuming you wanted to mod said sedan in the future?)
  • Like 1
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
