Worlds Biggest Low Mount.... With Pics
Griffin
 Share
How far from Newcastle are you? There is definitely no restriction with the 4 inch. Just need to return the bov's back into it and get a good quality filter.
I'm in Canley Vale, solid 2 hr drive away.
don't need the bov return or breather :)
I've got a 3" intake going to my 4" turbo, doesn't boogie well
Got some results, here is a dyno graph comparing the turbo that I took off. The red line was with stock wheels, the Green line with 19 inch wheels and 305 tyres.not sure if that would make a difference.
The actuator holds around 27 psi as shown, I wasn't expecting that so I need to get a lighter one to hook the boost controller back up.
It seems like the stock rb25 manifold is a restriction now so the next job is to make a decent one to see if we can get over the 400 hump.
Also the tune hasn't been adjusted for the different turbo as there wasn't enough time and I was only worried about it being safe to drive.
It drives great though. Can't wait to see what difference a good manifold will make.
I'm happy too that the internal waste gate works properly.
Looking forward to feedback thanks.
  • Like 2
Very similar one with different housings and the next size up turbine. Still not a bad result from a $50 turbo.
Not the last one wouldn't make any more power with more boost so I don't know if this one would make the same on less boost than what it's running. Currently.
  • Like 1
You should have gone external gate from the start, I have made 430+ on the stock exhaust manifold a few times now externally gated off the housing.
You could always run twin gates seeing that internal one won't open anyway. :)
You talking about my intake Johnny? Greg made 400kw through one in his auto, safe to say it will flow 450 odd. It's not like your turbo has a 4 inch compressor. :P
 Share
    • So, as it turns out, a new wire was the answer I went for, but getting there was not straightforward... Firstly, I'd been told before by shops that had worked on the car that it had some weird factory wiring, and I can now confirm that is true in at least a couple of places. For example....that very purple/white wire that provides IGN power to ECU pin 31.....I traced it out of the ECU loom into a connector high on the nav's A pillar under the dash, where it headed up and out of site across the dash, then back down at driver's A pillar. After trying about 8 different relays I found it coming into the back of the fuse box, and confirmed it was the same wire with a multimeter* (more to follow on that.... So, which fuse is the ECU IGN power connected to in my car?  Very top right, labelled IGN (good), 10A (good), Auto Trans Control (WTF?). It's not impossible it has been f**ked with before, but if so someone removed the pins from the back of the fuse box and moved it somewhere else, noting an AT control fuse would be functionally useless as the car was auto converted to manual long ago. It is not simply a wire cut and joined to the wrong place, both ends of the wire are the same colour just one is in the wrong location (you can see there is an IGN Engine Control fuse in the bottom row 4th from the right. Note, that is the fuse box sticker from my actual car, so either I have the wrong coin holder sticker, someone f**ked with it post factory, or factory sticker does not match the wiring.....whichever option it is just plain weird. Undermining the likelihood of someone having gone to that trouble to move a power feed when everything else in the loom had already been butchered....the fuse next to it IGN 7.5a ABS doesn't even have a wire running to it....so no idea where that fuse is on this car. All strange. But not the problem with my ECU power.
    • New tank clean paint and install complete 🤙
    • I have heard the frenchys kit (with the smaller toyota compressor) performs fantastic. i havent actually gassed my system yet, so cant confirm myself..
    • https://www.efisolutions.com.au/injector-lower-manifold-collars-adapters-r33-a32-y?gad_source=1&gclid=EAIaIQobChMIjpXb2aLaiAMVYcA8Ah1zkg6JEAQYASABEgJzG_D_BwE
    • correct Ive moved to a r33 oem ball joint - they are actually thicker than alot of the after market and similar
