How far from Newcastle are you? There is definitely no restriction with the 4 inch. Just need to return the bov's back into it and get a good quality filter.
I'm in Canley Vale, solid 2 hr drive away.
don't need the bov return or breather :)
I've got a 3" intake going to my 4" turbo, doesn't boogie well
Got some results, here is a dyno graph comparing the turbo that I took off. The red line was with stock wheels, the Green line with 19 inch wheels and 305 tyres.not sure if that would make a difference.
The actuator holds around 27 psi as shown, I wasn't expecting that so I need to get a lighter one to hook the boost controller back up.
It seems like the stock rb25 manifold is a restriction now so the next job is to make a decent one to see if we can get over the 400 hump.
Also the tune hasn't been adjusted for the different turbo as there wasn't enough time and I was only worried about it being safe to drive.
It drives great though. Can't wait to see what difference a good manifold will make.
I'm happy too that the internal waste gate works properly.
Looking forward to feedback thanks.
  • Like 2
Very similar one with different housings and the next size up turbine. Still not a bad result from a $50 turbo.
Not the last one wouldn't make any more power with more boost so I don't know if this one would make the same on less boost than what it's running. Currently.
  • Like 1
You should have gone external gate from the start, I have made 430+ on the stock exhaust manifold a few times now externally gated off the housing.
You could always run twin gates seeing that internal one won't open anyway. :)
You talking about my intake Johnny? Greg made 400kw through one in his auto, safe to say it will flow 450 odd. It's not like your turbo has a 4 inch compressor. :P
