^you will be more likely to rub the tyres due to increased diameter and speedo will also be out. I run 265/35/18 and they are just about right. If I was to go 275 or bigger I would be going with a 30 profile. Use a tyre size calculator on the webz and try to match the factory rolling diameter as close as possible with your new size.
https://www.sau.com.au/forums/topic/460372-will-this-rub/#findComment-7620001
According to ADRs and other stupid rules your apparently not allowed to fit a rim greater than 1" width and 1" diameter over stock. Sigh. I guess that's why most of us keep a set of some sort of stock rims just in case. but hey who could be farked getting defected.
https://www.sau.com.au/forums/topic/460372-will-this-rub/#findComment-7620005
What's the issue with increasing rolling diameter. I though what's important was to keep all 4 tyres the same size for the awd
yep, you need to keep all 4 wheels the same rolling diameter, you also want to keep this rolling diameter the same as factory.
your answer has been given, if your at stock height then it will fit but will not be ideal, your gonna have an incorrect speedo
https://www.sau.com.au/forums/topic/460372-will-this-rub/#findComment-7620014
Apart from incorrect speedo the 40 profile will it rub under normal driving conditions?
https://www.sau.com.au/forums/topic/460372-will-this-rub/#findComment-7620032
I believe we have 2" increase as the 33 ways more than 1400kg
FWIW guys, at least in SA, they do not actually still go by those old rules regarding a fixed number of inches increase in wheel width or wheel diameter. So long as the % change in rolling diameter is inside the limits you can do any diameter change you like. So that comes down to availability of suitable profile tyres. Same with the width. So long as track is not out of spec and wheels/tyres do not poke or have interference problems, you can have as many inches extra as you like.
Of course, practically this often works out to being not much difference to the old blanket rules anyway.
So while I know this to be the case in SA, it may or may not be in other states. But it was my understanding that most of the other states are being equally realistic about it these days. The old rules were written in simpler times.
https://www.sau.com.au/forums/topic/460372-will-this-rub/#findComment-7620160
    • Any advice? Yes. Learn to make your own lines, they're actually pretty easy and you can make hard lines, flexi lines, whatever you like, perfectly fitting to your application.  https://www.efisolutions.com.au/    sell a huge range of hoses, fittings, everything you need. You might have to outlay a bit in the beginning (eg I bought a 5 metre roll of stainless tubing that I've used less than a metre of) but still cheaper than buying premade shite hoses that sort-of fit.
    • If by axles you mean driveshafts, they're supposed to have play in them. They are not hard to recondition, it's just pulling apart the cv's, cleaning them and regreasing, fit new boots. I've only rebuilt one set and there was fk-all wear in them, still running just fine 8 years later.
    • Note, the aluminium bit that screws in the end that you have to remove to dismantle the rack is single use as it's punch-marked, it will strip when you unscrew it, and then you have to flatten the notch in the steel rack body, screw in a new aluminium end when rebuilding, then punch-mark it again once assembled. it is also 'somewhat tricky' to refit the rack>steering wheel linkage gear as it needs to be set to the right preloads etc. A rebuild is probably something that's better just given to a steering shop for a couple of hundred, unless you're mad-keen to do it yourself.
