Owned this for 4-5 years now, served a couple of years daily/street skid duty, then pull it off the road with the purchase of my new D40 Navara, until I figured out what to do with it.
10432106_10204142403094864_5690024402880
I Did some circuit racing and some drifting, and mate drove it at the 2014 skyline nats while i was overseas in malaysia, so when I got back, I ripped the whole car apart and stripped it back to a bare hollow shell, and started building something that could survive anything I can put it through, and still be a blast to drive.
1485106_10204672519228551_51193520510550
10734185_10204672517428506_3261961633965
10525666_10152483160526169_4424239221079
And here we are today.
specs
Body
Seam/Spot welded chassis
Boostworx CAMS spec full weld in cage
Type M Front bar/sideskirts/pods/wing
Origin 25mm FRP front fenders
Knight Racer 35mm GTR Full rear quarters
S14 Ganador copy mirrors
8000K HID kit,
Respray in factory black
Interior
Velo Viper seat in black, weld in floor mount rails, Velo Harness
Sparco Steering wheel/Lifeline Detachable hub kit/Attain shift knob
Racepak IQ3 Dash, Moroso Switch panel
Aluminium sheetmetal dash and rear firewall, Lifeline Firebomb extinguisher system
Engine / driveline
Rebuilt RB25 motor - CP Pistons/Spool Rods/ARP Hardware/Greddy Metal Head Gasket/Camtech 264/268 9mm cams, HKS cam gear, Performance Springs valve springs
K+N Pod, Trust TD06SL2-20G 10cm turbo/GReddy High-mount Stainless Manifold/Tial MV44 Wastegate
Plazmaman FMIC And piping
1 piece dump/front/3 inch straight pipe, Jun BL Blast pipe
Pierberg lift pump, Surge Tank, Bosch 044, XSpurt 1000cc Injectors, Aeroflow Fuel Rail, Aeroflow Regulator, E85 Fuel
Haltech PS2000 ECU, Haltech Wideband
Nismo GMAX twin plate clutch/Braided clutch line/urethane gearbox mount/Nismo pivot ball, Attain Solid Shifter
Nismo 2 way LSD, alloy diff mounts
Alloy radiator/Silicone Hoses/Nismo Thermostat/N1 water pump/GKTech fan
HKS oil cooler kit with filter relocation
Derale Power Steering Cooler
Optima Dry Cell Battery
Wheel and Tyres
Enkei RPF1 wheels in silver, 18x9.5 +15 (-5 with 25mm spacer) and 18x10.5 +15 (-20 with 35mm spacer)
215/40 and 235/40 Tyres
Suspension/Brake setup - FRONT
Cusco Comp S coilovers – 10kg
Cusco Adj. Upper arms
Cusco Adj. tension Rods
Cusco Tension Rod Brace
Nismo Tower Bar w/master cyl. brace
Kids Heart Free-dom Knuckles
KTS Tie rod Ends
Ikeya Formula Tie rods
DMAX Lock spacers
RDA Slotted rotors
ABC Braided Lines
Project MU HC+Pads
Suspesion/Brake setup - REAR
Cusco Comp S Coilovers – 8kg
Cusco Rear upper arms with eccentric lockouts
Cusco Traction Rods
Cusco Drag Links (HICAS Remval)
Solid Cradle Bushes
GKTech Subframe bracing kit
RDA Slotted rotors
ABC Braided Lines
Project MU HC+Pads
Project MU Handbrake drum shoes
Car is currently sitting waiting to have dash finished, then just paint interior, fully rewire car, wire in haltech and tune. Car is just running a basic loom of headlights/taillights/brakelights/single speed wiper/indicators/power windows and hazards. Haltech is being wired up in full stand alone, there is no factory wiring left at all.
Also seriously needs an alignment, paint needs to be wet sanded and buffed, all the glass put back in, and 1000 other small things. Don't need to buy anything for it though.
Right now, its covered in an inch of dust, and I haven't worked on it in 3 months, but now I'm motivated again, so when I get it back Ill screw it together and see what happens.
Im currently looking around at some new wheels and tyres, some 18x10's and 18x12's, and switching to semi's at a minimum
I don't know exactly what Ill use it for, but looking at doing hillclimbs, some circuit racing, maybe some more drifting. It'll still see some street duties from time to time, but not too often.
so yeah, not reinventing the wheel, just something super fun to drive that I haven't spent the national debt building.
  • Like 2
yeah, its just re-assembly, wire up the body loom, wire up the haltech, and plumb in the fuel lines, and all the littler things that need to be buttoned up.
Im a big fan of trust turbos as well, made 270 on 19 psi on 98 with a shit exhaust and no cams, now with straight pipes/cams/more boost and e85 I'm pretty keen to see the result.
and after being at the adelaide motorsport festival all day today, I'm keen as a f**king bean to get it finished now.
Interior is totally bare. Like, nothing atm. Getting a simple alloy sheetmetal dash bent up, and a new rear firewall for CAMS. Hopefully have it back this week.
This is what it looked like while building the seat rails.
this is when it was a street car...
Ill take some pics when I get it back and I've painted the interior and started bolting stuff in.
Ill be selling the RPF1's, if I can find something to take their place.
  • Like 1
  • 1 month later...
So, Finally got it back home.
Work starts first thing tomorrow morning. Clean up and paint interior, and start putting everything in, and get the car ready for wiring.
The pictures make the cage look like its at funny angles...
  • 3 weeks later...
See the little "cock" at the front point of the mirror? Cut that flush with the rest of the leading edge. Thats it.
I cut mine, but have yet to fill the little gap it left. It's on the to do list. Got the idea from adam and the run-it-hard boys and girls... Mine are just the $99 GKTech reps.
Dash looks even better now it's painted and has all the racepak etc. mounted.
Been busting ass all holidays, car is almost fully assembled, just got a few small jobs left to do and some touching up of paint and it's ready for wiring, cams and tuning.
Will take some up to date pics when I head back to work monday, My iPhone (work phone) stopped working first day of holidays and there's been no-one around to sort out a new one.
Been peaceful but. ;)
Edited by R31 drift pig
Was the limit with the guard flare I had and ride height. Was rubbing still on a couple of harder turns at malalla. Even with dampers wound right up. Was also running pretty serious camber haha. Could have rolled/flared more and gone wider, but I didn't need/want to. 235/40 on a 10.5 is MY perfect size, as is 215/40 on a 9.5. :nyaanyaa:
10.5's now have a 35mm spacer, and a 25mm up front, so am looking around at other wheel options, namely 12 inches wide, probable stay with 9.5 or maybe a 10 up front. Need to take some measurements etc after its aligned with the knuckles etc. in.
I haven't taken any better pics, took one yesterday arvo in bad light, shows that something's getting done haha.
Will take some better ones on the weekend out in the light.
Would love to see these Meisters on your car....
So would I... but A) Im worried about damaging them, Might try looking for something not so hard to replace, and B)Ill need to buy at least 6 wheels, front steer pair and 2 x pairs for the rear, so once again, not so expensive. I may just end up buying another pair of 10.5 RPF1's, Ive looked at rota's/XXR's/Concave concepts etc, but my enkeis only weigh 8kg's, so it's a fair bit of unsparing weight to add.
Keep me in mind when/if it comes time to sell your current set of rpf1s
I will.... and the 15 other people who've said they wanted them haha. but Ill keep you in mind.
I have no idea what Im going to do with wheels to be honest, Ill see what happens when I get it aligned and pull all of the camber out of the rear and if I need more grip. Might just need a decent semi in 235/40 and call it good.
As a side note.... Lexan Windows. Its happening. And no electric windows is just one more system I can delete from the car.
  • 4 weeks later...
So, little update....
Interior is all painted etc, bar the doors, all suspension arms are now in and everything is buttoned up, fuel system is finished, glass is going back in next week, just need to do a few other small odds and ends like mount the haltech etc, and its ready to go for body wiring, then cams in/haltech wire in and tuning. Reckon this thing'll go ok with 350kw's....
And I sold my Enkei's to a mate for his BA XR8 ute, so now Im on the hunt for wheels. It's currently perched on jack stands and it makes me sad haha.
May be rota 18x10/18x12's, May bring a set or 17x10/18x12 SSR SP1's out of japan, may get a set of 188.5/18x9.5 VS-KF's widened to 10/12, haven't quite decided yet. Depends how much i want to spend and what tyres I run etc... ill sort something in the next couple of weeks.
Show a few pics of your fuel system, particularly the surge tank, how you mounted the fuel pump and what was done with the fuel lines.
It's a good looking car, seem to have covered your bases pretty well with a lot of good bits. I'm interested to see how far the 20G compressor spec will go for flow (read: max power output). I reckon it will have great response, and even if you're capped at 300kW it's got the makings of a quick club car.
Thanks for the kind words... was actually your car that gave me the idea for the interior colour. Mines a machinery grey paint, super hard wearing, doesn't mark etc.
The fuel system is one thing about this car I'm not very happy with, surge tank arrangements in 33's are always ugly, and mines no exception> I am a bit OCD about it though haha..
surge is currently on the passenger side, tried to put it where the battery used to be (Battery is now on the passenger floor, with fire suppression system) but I couldn't get nutserts to fit through that panel. The hoses now run up across the old battery tray, and down into the factory hardline, up to the front, into an aeroflow fuel rail.
Im still in two minds about removing the current system, cutting out the floor, and putting a cell, but trying not to spend money i don't have to, Id like to drive it at some point. Aeromotive do a nice cell with an inbuilt swirl pot and 1000hp or 1500hp fuel pump, but at nearly $1500, I'm a bit hesitant to spend the money; Although I know Im limited to how much further I can go with one 044, so anything more than this will require more money spent regardless.
Im pretty keen to see what the 20g'll do, mine's a SL2 model, so will go a bit higher. I previously made 270w's on 98, with a shitty exhaust and blocked cat, the car my kit came off off made 300 on 98, so with decent sized cams like i have, E85, and a decent tune, reckon ill see 330-340 fairly easy. At the end of the day though, it's only a number. Car was actually pretty quick with 270kw's, just had no grip haha. Full boost is around 3400-3500RPM, and previous limiter was 7200rpm, new limiter will be 8000 rpm, so gives a pretty sizeable power band to play with. And the gearbox/diff ratios etc all seem pretty nice to work with, its a lot of fun to drive around malalla.
Just need to keep working and finish off all the little tedious bits and pieces, so when wiring etc. begins, it's fairly straight forward. And with my 1st child arriving in 10 weeks, I've got a lot of work to do before then haha.
G'day, Ben
Your humorous topic title caught my attention. I then saw the track photos and realised it's an SA based car. Then the penny dropped... the black beast from Boostworx! I've had a decent look over your 33 a couple of times whilst it was in at BW.
I've known Shaun for years, well before BW existed. My burgundy 33 is a regular there and was sharing workshop space with your car for a fair portion of 2015.
I'm keen to see the end result of your build. I'll be sure to check back from time to time.
Cheers,
Matt
Hi matt, Very familiar with your car too! I started going to shaun just after he opened BW, remember your car was always on the hoist closest to the door? I was driving RX7's back then haha.\
Mine's fair rough compared to yours, but i didn't build it to be too pretty, Ill probably fix some of the average bodywork after it's finished and blow another coat of paint over it.
It should be back @ BW in the next couple of months, once the body wiring is finished, Shaun's sticking in the cams for me and wiring in and tuning the Haltech for me.
Cheers for the kind words, keeps me plugging away. ;)
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
