Hi all,
My R34 GTT passenger door lock has started playing up and won't lock sometimes so I need to check it every time when parking, annoying.
I just pulled the door panel off and had a lock at the mechanism, see photos below.
The rod system seems fine and I WD40'd everything whilst there but it didn't really help.
What I noticed is that the door locks when the actuator rod is disconnected, so the theory is that the actuator has become too weak over time to move the whole system.
Any other suggestions before I go and buy a new actuator? It's a sedan too so finding one is going to be fun...
What's involved in changing the actuator? I'm not quite sure how to disconnect the door handle rod, and also couldn't see any actuator wiring/plug anywhere, though it could be somewhere inside the door skin.
Cheers
Edit: This was a good reference on how to get the door panel off: http://www.sau.com.au/forums/topic/285604-tutorial-r34-gtt-door-panel-removal-guide/
Edited by V28VX37
  • Like 1
Any suggestions? Does anyone know if the coupe and sedan actuators are interchangeable?
Hey man I've got the same problem, passenger side aswell haha (R34 25GT Series 1 sedan)
Started playing up a couple weeks ago
Wouldn't be so bad if the problem was unlocking but that seems fine, just locking is the problem
Not much info googling this problem... wonder if we can just buy an actuator from a Nissan dealership?
Looking forward to any suggestions! :anyone::/
  • Like 1
That sucks, sounds very similar to my issue.
I haven't made much progress but have found some actuators at http://www.brisbanemotorimports.com.au/nissan/vehicle-electrics/door-lock-actuator/
Looks like they have all other actuators in stock except for the front passenger, grr. I am pretty sure you could get one from Nissan for like >$200...
  • 3 months later...
  • 10 months later...
I replaced the actuator (DIY: https://www.sau.com.au/forums/topic/465953-replacing-door-lock-actuator-in-r34-gtt/ ) and it worked well ... for a while.
It's started to play up again, same symptoms as before, always unlocks but sometimes doesn't lock.
I'm wondering if it's something else that might be jamming it? I'm thinking of attacking the mechanism with WD40, any ideas where to focus on?
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
