  • 4 months later...
44 minutes ago, JGTC said:
Marvelous, box whine on a street car must get old at some point, but for us peon spectators it is fantastic.
Yeah I love it - cars done 1173km in 5 years - so its not daily driven - but I'm with you - would be tough on a daily.
  • Like 1
You should take a crack at drive it daily for a week or 2*
*assuming you commute to work in a car
  • 1 year later...
Hey
Been awhile since an update..... car hasn't moved in awhile....
After much - and I do mean much research & questioning .... I have finally taken the jump......  new box has been decided & ordered!
I went with the Albins ST6-LP(Low Profile billet casing - direct fitment) with the HyperTune Shifter kit and associated accessories (cross member, etc) and bits. ???
New ECU and other items coming as well!
Watch this space!
Dan
Edited by IMACUL8
spelling!
  • Like 6
21 minutes ago, Shoota_77 said:
Holy shit that is a work of art! So much billetness....
Yeah - and they anodize the box any colour you want - I'm thinking leaving it as is and having it clear coated.  Thoughts?
Clear coat it for sure!
An anodised candy colour would stunning too but maybe too try hard show car? Either way it's impossible to make that work of art look anything other than amazing! I'd eat my dinner off it...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
