  • 1 month later...
On 11/9/2020 at 11:15 AM, SimonR32 said:
Updates on the Albins?
No.  Over 12 weeks now and no eta to date.  Was supposed to have it by now.   Joke. I just this afternoon enquired about cancelling.
Muppets.
Edited by IMACUL8
Muppets.
Albins have moved into the defence industry sector and since this move there customer service regarding their sequentials has gone to poo.
Yes I have heard that from a few people now. Real shame.
  • Sad 1
7 minutes ago, PranK said:
Love that wheel!
Thanks Christian....  I'm having an R34 GTR wheel done at the moment as well - a man needs options!
Edited by IMACUL8
  • Like 1
56 minutes ago, BakemonoRicer said:
Imagine the lead time in the event you need replacement parts
best of going with a samsonas mate! They are used in all the TRP shop cars and their after sales service is pretty spot on
Im looking into it now mate.. waiting to hear back from my workshop.
+1 for Samsonas. Can't fault the box nor the customer service.
Only downside is if parts aren't in stock they need to come from Lithuania but even that is faster than Albins at the moment...
Case on its way for Anodizing and things are moving.
At end of the day - do I really need a Albins, Samsonas, Hollinger etc?  No.
Car has never seen a track day, drags, etc.  Occasional street driving, cruzin, etc - and back in the garage.
Its way over kill for what I will ever need - but - hoping I will never have box issues again (at least not for a very long time).
I am setting up the internal oiling system on the Albins to run to a rear diff cooler (Z Tune style)....  again huge overkill for me - but fark it ;) will be functional and look amazing.  I have also slightly tweaked the shifter /strain gauge setup/look to what's offered standard.
Adding a new Motec ecu and c1212 dash etc. when the box goes in.  (thanks to Moray).
Ill just chill and wait - I'm sure this box will be more than I ever expected or needed!
Its a investment (that's what I tell myself so I don't cry) ;)
Dan
Edited by IMACUL8
speeling ;)
  • Like 1
Adding a new Motec ecu and c1212 dash etc. when the box goes in.  (thanks to Moray lol).
Ill just chill and wait - I'm sure this box will be more than I ever expected or needed! lol
Dan
Is the case the issue, because that's not made by Albins, I figured Albins is the hold up?
Albins makes the case - they send to Platinum - they anodize and send back for gear set to be installed.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
