  • 1 month later...
On 11/9/2020 at 11:15 AM, SimonR32 said:
Updates on the Albins?
No.  Over 12 weeks now and no eta to date.  Was supposed to have it by now.   Joke. I just this afternoon enquired about cancelling.
Muppets.
Edited by IMACUL8
Muppets.
Albins have moved into the defence industry sector and since this move there customer service regarding their sequentials has gone to poo.
Yes I have heard that from a few people now. Real shame.
  • Sad 1
7 minutes ago, PranK said:
Love that wheel!
Thanks Christian....  I'm having an R34 GTR wheel done at the moment as well - a man needs options!
Edited by IMACUL8
  • Like 1
56 minutes ago, BakemonoRicer said:
Imagine the lead time in the event you need replacement parts
best of going with a samsonas mate! They are used in all the TRP shop cars and their after sales service is pretty spot on
Im looking into it now mate.. waiting to hear back from my workshop.
+1 for Samsonas. Can't fault the box nor the customer service.
Only downside is if parts aren't in stock they need to come from Lithuania but even that is faster than Albins at the moment...
Case on its way for Anodizing and things are moving.
At end of the day - do I really need a Albins, Samsonas, Hollinger etc?  No.
Car has never seen a track day, drags, etc.  Occasional street driving, cruzin, etc - and back in the garage.
Its way over kill for what I will ever need - but - hoping I will never have box issues again (at least not for a very long time).
I am setting up the internal oiling system on the Albins to run to a rear diff cooler (Z Tune style)....  again huge overkill for me - but fark it ;) will be functional and look amazing.  I have also slightly tweaked the shifter /strain gauge setup/look to what's offered standard.
Adding a new Motec ecu and c1212 dash etc. when the box goes in.  (thanks to Moray).
Ill just chill and wait - I'm sure this box will be more than I ever expected or needed!
Its a investment (that's what I tell myself so I don't cry) ;)
Dan
Edited by IMACUL8
speeling ;)
  • Like 1
Adding a new Motec ecu and c1212 dash etc. when the box goes in.  (thanks to Moray lol).
Ill just chill and wait - I'm sure this box will be more than I ever expected or needed! lol
Dan
Is the case the issue, because that's not made by Albins, I figured Albins is the hold up?
Albins makes the case - they send to Platinum - they anodize and send back for gear set to be installed.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
