@IMACUL8 At a minimum I recommend this:
https://www.nzwiring.com/index.php/product/trigger-kit/
The OEM CAS is terrible on big powered cars, you always end up with triggering errors at high RPM.
Of course a proper crank/cam triggering kit is best.
  • Like 1
Thankyou - appreciate the suggestion.
  • 3 weeks later...
  • 1 month later...
Nice car Dan.
The Albins appears to be a good gearbox simply going off the word of mouth around the traps so to say, I'm unsure who you were ordering it through or the custom 3rd party casing/adapters to fit in the R33 tunnel as described, assuming PRP then is the reason for your problems.  Yes mirror image of what you said , things magically going missing, stuff that you paid for doesn't end up being in box (why is that so common??),  general bullshit that is no good and shouldn't happen especially as it's a 30K spend the guy that runs the show cares not about the stuff you wrote about (work hard etc, pay big money, pay for best product = let down) also customer plays part of the R+D of the custom bits / linkages or whatever at their expense and burden.    After sharing a similar view to you, I got bluntly advised its a privilege to even have any of their products so the waiting time (bullshit excuses etc, stuff magically grew legs walked out of the box, dissapears or magically somehow didn't end up in the box as you describe), which I experienced too ofcourse.
The EFR8474 you bought off me is a great little unit very similar to the 9180, yes it's snappy and drove like you described and it's best suited for something to punch through a few gears in and then just cruise once upto speed, it was great in a H pattern box coming into each gear so I can only imagine how great it works with the sequential keeping it on boost.
Edited by RB335
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
