Hey guys.
Looking to hear about experiences good/bad with running shimless buckets, ideally in a worked head.
Possibly looking at going down this road, getting mixed opinions though.
My situation: running 1mm oversized ss valves, 272 cams with a decent lift ( head relieved ) springs, ported etc. was running standard buckets, shimmed.
Ended up having a shim pop out of place, very lucky nothing touched, no damage..
Looking at running shimless buckets and having it all setup to do so.
Would like to hear feedback from anyone who has done so and what they think. Reliability, wear, maintenance ..
Thanks
https://www.sau.com.au/forums/topic/460457-rb26-head-shims-vs-shimless-buckets/
When saying shimless, you actually mean the thicker buckets as you still need to shim them anyway to achieve the correct valve clearance.
Its to do with the base circle of the cam, if its smaller than stock you need thicker shims, or use the thicker lifter with thinner shims.
Now having said that, most shims that ive seen spat out where when smaller base circle cams were used with standard buckets and thicker shims.
For some reason the thinner shims used with thicker buckets stay in place better than the thicker shims with stock buckets......
Yes valve float is the enemy.
Yes, proper shimless buckets can become expensive when coupled with aggressive cams (which is of course one of the main reasons for wanting shimless buckets anyway!) because clearance changes (wear) will become more frequent and you can't just ignore it. Have to buy some new buckets each time you have to adjust anything. If you suffer any valve seat recession at all you will come to hate it also (same reason).
Some VQ's run shimless Peter, you need to order a different bucket if the clearance is out. Sounds like hard work to me.
That would be a absolute total pain in the arse.
RB26 run with shims without issues when staying around factory shim thicknesses.
Our current setup is 280 degree 11.5mm lift cams with thicker buckets but with stock thickness shims, the only reason i went for the thicker buckets was because of the thicker shim issues.
Another head near my place was assembled with the same spec cams and same bucket/shim setup for a 28 thats turning over 9000Rpm ATM without shims falling out.
Both us use new double valve springs with seat preload and lift tension checked and adjusted with shims also under the valve springs, something which most workshops dont check and adjust.
That can make of break your valve bounce issues......never assume that the seat pressure is correct even when using new springs, all you need is a valve that sits a little deeper and you know whats going to happen.....always put a little more spring preload in because they will go soft with high lift cams and heat cycles, not too much because you dont want to chew out your nice new cams.
Edited by GTRPSI
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
