gohan does mean 'rice', but it also has a 'meal' connotation. It also specifically means 'boiled rice'. Gohan is two kanji too, though the first kanji (written as hiragana above) isn't what I'd consider to be basic kanji.
the first thing that popped into my head when I read the OP, was kome
I'll go see if I can google up an image
https://www.sau.com.au/forums/topic/46046-jap-char-for-rice/#findComment-936017
that one worked better :D
should be phonetically read as koh-meh
below it are various readings for it: kunyomi - japanese derived readings, and the onyomi - chinese derived readings (different readings are used for different kanji combinations, etc).
kome can be used for rice that you are eating, the sack of rice you are buying at the supermarket, or the rice growing in the field. It often has the honorific 'o' attached to it (ie: okome).
The correct way to write it is
1. short top left stroke
2. short top right stroke
3. horizontal stroke
4. vertical stroke
5. long bottom left stroke
6. long bottom right stroke
What I find ironic about this kanji - is that it is also the kanji for 'america' ...america is katakana-ized as 'amerika', but the kanji-fied version is 'beikoku' = the kanji above + 'nation' kanji (koku/kuni). I've been told it has to do with the sound of the kanji - nothing to do with the concept of 'rice country' - but I'm strongly of the belief that 'rice' (in car terms), is an american phenomenon, and just something the japanese copy and get blamed for (I'm sure some of the other sau japan locals will agree).
https://www.sau.com.au/forums/topic/46046-jap-char-for-rice/#findComment-936049
owned: on paper, performance-wise, the JDM version I-III FDs (mine is a II) are pretty much on par with an r32 GTR (0-100 and 400m are very close). Though they are world's apart to drive - obviously rwd for a start - far less driver assistance ('pure sports' is the term often bandied about), very light (mine is 1260kg, some are a touch lighter), 50:50 weight. I love hammering a high-powered 4wd turbo around in the wet - but on a dry track - it doesn't come close to the adrenalin rush of the twin turbo rotary... which never seems to run out of power and just loves screaming high revs - combine that with arguably the best rwd chassis to ever come out of japan...
Power delivery is quite different, the lack of torque w/ rotary is one criticism that has been made - but when you are going 0-100 in under 5 seconds - I have to say "ahh... who cares, goodbye!". I do prefer to drive the ej20t powered forester around in traffic though (it's a more liveable beast in most ways).
https://www.sau.com.au/forums/topic/46046-jap-char-for-rice/#findComment-936070
ご飯 - gohan
Jeez Merli, you flunked Japanese 1.01 didn't ya? :P
Gohan - cooked rice
Kome - 米 - rice (uncooked, like in a bag)
Edit: Holy shit... I was a bit late in replying wasn't I? Whadda tool! :Oops:
https://www.sau.com.au/forums/topic/46046-jap-char-for-rice/#findComment-936195
btw, have fun with the new ride :rofl: where's the thread??
Mada mada... ;)
Actually, the car hasn't been signed over to me yet, and theres still some things to fix up on it (right Troy?) before I pick it up... I'll have a thread up at the beginning of August. We'll be heading over to the Pokka 1000km Taikyu race in August in convoy too, should be good.
https://www.sau.com.au/forums/topic/46046-jap-char-for-rice/#findComment-936668
Jeez Merli, you flunked Japanese 1.01 didn't ya? ;)
Gohan - cooked rice
It's been a while since I've had to speak japanese :)
And I don't think I ever learn't the word for "uncooked rice in a bag" :rofl:fawk.gif
https://www.sau.com.au/forums/topic/46046-jap-char-for-rice/#findComment-936788
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
