Well if its a piston ring or something it is in to some serious time/money to refresh and depending on how long the other guy ran it could be one hell of a head ache.
Hope it is just the HG then you will be away laughing.
Even with that shitty compression the engine should still start and run. (will probably be rough). If it was mine, I would persevere in getting the thing started, just to get a bigger picture of the overall condition of everything else and then making a more informed decision on wether to fix or part. As said a hg is your best hope and may or may not be the issue. I have replaced one before, it is a time consuming job but not all that difficult, there are plenty of guides online and if u can get someone with some mechanical knowledge and tools to lend a hand it is very do able.
good news !! i got it started !! although it ran rough. had to keep foot lightly on accelerator otherwise i recon it would of conked out.thing is loud as hell lol
i couldnt rev it past 2500rpm (somewhere around that mark ) is that due to compression or using stock ecu with 800cc injectors and no afm,,or both lol
im just happy i got it started.ill put more fuel in, i noticed the fuel light was still on when i started. for some reason fuel pump wasnt giving me a reading after putting fuel in and turning ignition on ( maybe from having it unplugged ? )
not really sure where to go from here
also when i reved to 2500rpm it pretty much stayed there. sounded like fuel cut or something. so im guessing thats from using stock ecu ?
minds racing right now thinking what to do now lol
ok thats what i figured. i cant really spend anymore money for a few weeks now. so i;ll google how to set up the vipec ecu. assuming its not damaged. it was giving 2 error codes last time i checked but they werent serious ones from what i remember.anyone have any links on how to set it up ? i could print screen my laptop while using the software and maybe someone will notice what wrong in the setup ?
you're welcome... lol i talked to someone at vi-pec and this is the reply i got " Unfortunately I am going to be the bearer of bad news. There is almost a 100% chance the reverse voltage will have damaged the ECU. When this happen it often takes out the ignition drives and the Aux output drives often with extensive PCB damage. Best bet for a start will be to open the ECU and see how bad it looks. If the PCB has damage it could be a costly repair"
so i guess i'll be opening up the ecu tomorrow and i'll take a photo and send it to him. but not liking my chances. sucks cause that's an exspensive ECU :(
definitely cant afford a new one for awhile which sucks.
New ecu and engine rebuild.
Then see if clutch and gearbox, brakes and suspension are ok.
Have you checked to see how rusty the chassis rails are yet.
Supposing that its repairable what are your chances of finding the person who tuned it last and seeing if they have the tune saved on their computer? If so that would be a good starting point to get it running.
I think we have proof that the ECU suffered. Only having some of the coils working is a solid indicator. That would tend to suggest that the ECU may need to be considered no longer useful. From that point, the question becomes.....what do you do now?
Fixing the ECU probably really means a whole new board rather than hours spent replacing components, testing and hoping that there isn't other damage hidden in there waiting to pop up once it starts working properly. A whole new board has got to be a large % of the whole ECU price.
You have a stock ECU and could Nistune it, but that is $ and then you'd need AFMs which adds more $$.
And then you have at least a head gasket, possibly other detonation damage, etc etc.
Parting the car might be the smartest option.
I agree, you have an RB26 with issues and a damaged ECU both of which are going to cost cubic dollars to fix properly.
Part it out and buy a runner, you'd be surprised how much you'll get for the components.
Hrrm I'm not sure what to do now. And for parting it out. I wouldn't know what to put prices on everything and I can't be bothered taking it all apart either lol. Well I'll check the ecu tomorrow and take a pic and go from there.ill look into nistune too see how to see how much. I had my bluebird ecu nistuned. Don't remember it costing that much. I have a z32 afm if that's possible to use
I started the car again earlier to make a video. It wouldn't start unless I primed the fuel pump a couple of times. Not enough fuel pressure or something? Was getting a couple of little backfires whole idling too. Probably a bit of shitty fuel? I don't know my brain hurts from all of this lmao
I'm putting the video on YouTube soon and I'll post the link
You can look through the for sale ads here to see what people sell parts for. You'll get shouted down if people think you're too expensive and you'll get dozens of PMs if your prices are low.
It's not that Nistune is expensive, but by the time you buy the board and get it fitted, then tuned, you're looking at >$1k. So you have to factor that into your comparison against trying to make the Vipec work. And you can't use a single Z32 - you need 2.
With respect to the car running.....this seems to be surprising given how many coils you supposedly didn't have working. If I had a 6 cylinder with only a couple of cylinders firing, I would hesitate to call running "running" and my language about backfires/pops and throttle blips would likely be a lot stronger than yours. Maybe your ECU is not as borked as we fear.
all coils are working with the stock ecu. i didnt try start it with the vipec since i knew it was only sparking on 1 or 2 cylinders. i changed all the spark plugs after i did the compression tests too.
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
