Im looking for some ideas on my next stage of modifications.
My current setup is as follows
340rwkw @17-18 psi on BP 98
Rb25det Neo
Stocks gasket and head bolts
Stock motor
Tomei Type B Poncams
Kinguawa T67 25G 10Cm
Nz performance Hi mount with 44mm gate pipe
Tial 44mm Gate/38mm screammer pipe
Greddy FFP
VH45 TB
Greddy Twin entry Fuel Rail
Sard 880cc Injectors
Sard fpr
2.5" cooler pipeing
Greddy Type M intercooler core
3" DUMP
Blitz Nur Spec R 76mm
Im now Looking for ideas of were to go next id like to find some more midrage power ,Ideas are
Going to a 4" dump
ADJ Exhaust Cam Gear
Possibly E85
3" cold side cooler pipeing
8cm Rear Turbo Housing
Dont reckon you'll gain too much with a cam gear. Maybe a bit.
Best bet is to piss off the GReddy plenum and go back to factory; will lose some peak power but gain heaps of midrange.
Im aiming for around the power you have now, with a TD06L2 20G, and have kept the factory plenum for exactly that reason. Am using Plazmaman piping to keep clear of high mount turbo.
Think injector size will be too small for e85, and possibly fuel pump.
Can run on e85 and see what you get?
Don't need to change cooler piping/exhaust/exhaust housing at all either.
Edited by R31 drift pig
I went greddy inlet for shorter pipeing and neater engine bay wont be changing that.
I am keen for e85 but closest pump is 45 mins from me so will need to get a 44 gal drum and store it at home.
Think injectors would be on the edge with probaly 380 ish with e85 .
Pumps will be fine 044 and 0404
I made 310rwkws with a TD06-20G on an RB20 with E85. Having run a T67 and TD06 and a billet 73HTA-TD06 on my RB25 I personally rate the 20G or the 73HTA better than the T67. Spin 20psi through one and you will make 320rwkws with a crap load more mid...though you will find you dropping the rev limit to 7,500rpm as the show is over by then.
If I can get a 10cm I will be putting the 20G back on my car and selling the T67
  • Like 1
That plenum is where you'll find the most gains with the way your engine is setup. (keeping everything else the same that is) Shorter piping is no match for the midrange that the factory plenum provides. Well proven.
And reckon you'll run out of pump around the same level as the injectors. (On e85 that is)
My tuner advised me that safe level for single 044 on e85 with is around 360-380 kw. May have to add a 2nd 044, which is easy to do with your rail.
Out of interest, what do you reckon a 20G will make on e85 on a 25?
With the tomei cams, do you loose vct? Any reason you went type b over a?
Believe they both retain VCT.
If you keep the drum off the ground with some wood or bricks, it'll be fine for 12 months.
I do the same thing, but liberty Main nth road is 5 mins away from home.
Maybe switch to e85 first and see what it makes, if you run out of injector switch to some 1000cc's, or 1200's, and add another pump if need be too.
I would like to stay with the t67 as although this is now a street car it will still see the track pluss i have a spare core for it to i just had rebuilt.
I know there is room to find torque bye getting rid of the ffp but im not willing to remove it as i just like the look and gives headway for crazy power.
I beleive a 044 will support 400 on e85 i could be wrong more then happy to add another if i need to injectors well id like to not have to change them but if need be i can.
I went type b because i got them for a good price wanted choppy idle and because race car hahah
I first built the combo as a drift car but has been transfered into a streetcar.i was looking to go 400kw like simon r32 did with my previous motor that had studs and metal hg with this motor i havent done that so dont want to put much more boost through it
I'd keep the cold side piping the same size as the turbo outlet.
The FFP seems to have varying results, I wouldn't put one on a car now but also wouldn't take one off if it's already on there.
If e85 is not convenient could do the e42 mix.
There's a post from Status here somewhere saying the 8cm doesn't seem to be that much more responsive but loses about 30 or 40kw up top so if doing something with the turbo I'd probably go to a BW or PT.
Stock cams & TB may make it feel a bit better in the mid range.
E42, more boost & maybe head studs
Loves it till it goes bang
If anything is going to stop it going bang, e85 is it. I don't understand why so many of you guys are still using that petrol crap. :P
I understand it can be hard to find in the country but a little proactive email campaign to United would have a pump fitted in no time I suspect. We need an ethanol lobbying group setup as the rollout seems to have stalled due to base stock prices skyrocketing.
As Johnny mentioned, your head studs will be the issue with that much cylinder pressure.
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
