Yea i understand that i dont have the fuel system for anything more then 18 psi.
what? lol
I run 875cc Siemens Deka IV and it is only hitting like 89% duty cycle at 24psi
I prefer to tune with loads of boost but very lazy timing rather than loads of timing but not so much boost.
Because you're on E85, EGTS are shit low
Guess i just have to wait to see what the cyle is when there on the dyno.
I thought the whole idea was for heap of timing with e85 isnt timming safer then boost.
Id like to think with like 23 psi it would go over 400 but studs would be realy helpful for that
What power are you making with them only at 89 %
Edited by Ke55pig
I don't know how much I'm making but last time I put it on a mainline 2WD dyno it made 340kW but only with 22psi but that was with stock stocks a little more timing. I'll shaved off the timing and added more boost for the track, against what everyone would think lol.
However I've got ARP studs and I've over torqued them to 108nm (non 2000 studs)
Out of interest, what do you reckon a 20G will make on e85 on a 25?
310 to 320rwkws should be a breeze with the 10cm housing. I made 310 on an RB20 with an 8cm housing
If its a street car put an 8cm housing on it and with E85 if there is a tad too much back pressure it wont matter. on 98 the backpressure woudl hold it back and make it puing with boost and exhaust but with E85... I know the 8cm housing on the 20G on my RB25 was EPIC.
I have a L2 20G 10cm. I was hopeful of around 330-340 with the cams Ive put in, camtech 264/268 9mm's. Cant seem to find a lot about the l2 20g on a 25 for some reason, mostly the 25g/t67.
I making 340 on mailine roller on 98
Ive been in a r34 with a t67 25g 10cm, and less engine work done (Injectors/FMIC/Power FC/Z32/Nismo Pump/Exhaust and turbo kit) and it was pretty damn good on the road, made 300ish on 98, so I can only imagine how good yours'll be with the extra gear on e85.
Edited by R31 drift pig
Yea looking foward to it its bye no means slow just needs more mid more then happy to make no more peak on e85.
It will be on dyno to sort out splutter jolting issue as soon as goes into positive pressure/boost.
New cas new afm new coils and new loom didnt fix hopeing its a easy fix fingers crossed
Edited by Ke55pig
Hey mate, just looking at this. In your first post with the dyno sheet, the AFR's get REALLY rich as your starting to make power it looks like 11.4:1 ish but for some reason, being not enough time invested by the tuner or unstable fuel pressure the AFR's are all over the shop.
If the tuner can get a stable 12:1 AFR's while under full load that will also help with the miss and help in ramping up your mid range( it's not going to be a crazy gain but power delivery will be a lot more smoother and keep the heat higher in your exhaust to allow for greater thermal expansion and inturn turn the turbo faster)
Just a few things that seem to jump out at me.
Good luck with E85, you won't look back.
Going rich as you reach peak torque and at peak torque will prevent knock, especially on 98RON. I assume that was done on purpose.
On E85, that doesn't matter so much...
I personally tune my car and my mates car using the same technique.. as it approaches max torque and is at max torque AFRs are in the 11.5 region and as torque dies down it leans up to nearly 12
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
