I noticed one thing, you have a SARD FPR... those things aren't that good.
I replaced my SARD FPR with a Turbosmart 1200 FPR and AFRs were more steady on WOT and also my fuel map could be smoothed out
So word from tuner is pump will be fine going to see if he can get some good midrange gains and whatever it makes up top will be conservative hoping for 30-40 kw from 3800 up and maybe peak of 360
Postponed till Tuesday Wednesday .
My running issue was a hole in my intercooler wonder why it was bit laggy lol
so purchasing a cooling pro intercooler for now,
They also managed to rewire my fuel pumps to get me 13.3V at the pumps.
Only changes were a colling pro intercooler instead of greddy one and type r exhaust not a straight through.
Fpr also started play up and injectors almost out
didn't I say the SARD FPR isn't that good?
I doubt the injectors are nearly out.. it's because your fuel pressure is all over the shop up top. I found that when I changed my FPR I ended up with richer mixtures and needed to fix up my VE table.
Yes yes you did bit dissapointing from a genuine jap item. Will replace as soon as i have cash.They offerrd to clean the tune up ounce i fit a new one up.
Not almost but getting on the higer end but plenty left in them for now.
General appearance is that you've picked up 30-40kW from 3000-7400 using marginally less boost. But the peak power number is roughly similar despite the gain right through the range.
How is it that the boost curve comes on at lower rpm?
The power throught the curve is so very noticable as is the added response i cant answer how it come on earlier but its certianly noticable.
The peak power is about the same but how often do u rev above 7200 . Beleive its the same due to exhaust restriction and it has very little timing as my motor has god oddly low but even comp so wanted to stay conservative
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
