Hey guys. So I bought a 1994 R32 GT-R. Car drove amazing when I first got it. It only has 84,500 km's on it. The weekend of the week I picked it up. I decided to do a service which entailed:
. Oil
. Oil filter
. Air filter
. Rocker cover seals and half moons
. New front brakes
. Fuel filter
. Iridium spark plugs
The car already came with splitfire coil packs.
After driving for a couple of days, I noticed my car started to have a bit of a stutter. Wasn't bad. Few weeks later I went for a drive was stuck in traffic for a bit then when I started to drive it started to misfire severely. It started to sound like a wrx. It was a warm day but it never used to do that. Took it to an auto electrician tested everything possible that could cause a misfire and everything was getting power. Did a comp test all cylinders had the same reading. Changed coil packs and spark plugs and it still does it. When it's first started and driven it's fine. As soon as I drive for 30 mins it starts to miss. Even if I have short drives, turn it off start it again it struggles at idle thwn revs pick back up. I lose alot of power and is super sluggish!
Any ideas on what it could be?
https://www.sau.com.au/forums/topic/460506-misfire-issues/
Did you throw out your old spark plugs? Try throwing them back in - my first ever mistake when I bought my car was my initial home service... I didn't gap the spark plugs properly.
Also try doing a warm compression test and leak down test immediately after it starts shitting itself...
https://www.sau.com.au/forums/topic/460506-misfire-issues/#findComment-7624602
Yeah see i threw my old ones out. I put iridium ones in. I took them out to notice that one of them was cracked.I put cheap ngk ones in because that's what was in it originally but it still stutters and sounds like it's choking! The compression test I did was hot. Was making compression fine! Do you thibk I need a bigger gap?
https://www.sau.com.au/forums/topic/460506-misfire-issues/#findComment-7624738
Do the AFM solder fix.
This. Search the DIYs for it.
BTW opening up the plug gap makes it harder for the spark to jump, so if you're troubleshooting a missfire at max torque you would close it up.
https://www.sau.com.au/forums/topic/460506-misfire-issues/#findComment-7624802
That happened to my car before massive pain in the ass can't even get my hand on it that's how shit the spot is right up against the firewall on the intake manifold gasket about a 4 mil chunk spat out. best way to check is pump compressed air through the pipe work after the cold side of the intercooler and test for air leaks you hear it gushing out at the back at the firewall it's in a flamin mongrel of a spot it would be easier to pull the engine out and change all your gaskets at the same time to metal ones even head gasket would be worth doing while engine is out.
https://www.sau.com.au/forums/topic/460506-misfire-issues/#findComment-7626919
    • Cool to see you're on the forum man, think you've met my twin brother a few times (Brent).
    • Yeah...but NA Mercedes V12.
    • Yeah everyone always seems to refer to them as S13 wheels however they came on R32 Skyline, A31 Cefiro, C33 Laurel etc., and also came polished diamond cut or painted depending on the model. Congrats on your GTS purchase! I'd personally leave it NA.
    • In this thing about this 100% renewal energy stuff I hear no one really talking about anything other than power and fuel really Power and fuel, whilst being a huge part of how we use the billion year old Dinosaur juices, are only 2, of the probably thousands of things that we need to use it for in the chemicals industries for making nearly everything we use nowadays I'm all for a clean planet, but if we want to continue to have all the day to day appliances and stuff that we rely on everyday we will still need fossil fuels Whilst I do love science, and how it can bring innovation, there's really a limit to how far it can go in relation to "going green" As for EV's, unless your charging of your own solar panels, it isn't helping the environment when you consider the the batteries, the mining processes required,  the manufacturing process required, and how long a batteries (read: the vehicle) lasts long term If I was supreme dictator of the world, I would ban the use of sugar for fizzy drinks and food additives and use that for ethanol manufacturing, petrol engines would be happier, and people would be alot healthier  Disclaimer: Whiskey manufacturing would still be required, so says the supreme dictator of the world Same same for all the vegetable oils that get pumped into all our food, use that for bio diesel Disclaimer: the supreme dictator would still require olive oil to dip his bread in This would take some of heat off the use of the use of fossil fuels which are required for everything we use, unless you want to go back to pre 1800 for heat and power, or the early 1900's for plastics and every thing else that has come from cracking ethylene  Would I be a fair and just dictator, nope, and I would probably be assassinated within my first few months, but would my cunning plan work, maybe, for a while, maybe not Meh, in the end in an over opinionated mildly educated arsehole typing out my vomit on my mobile phone, which wouldn't be possible without fossil fuels And if your into conspiracies, we only need the fossil fuels to last until a meteor hits, or thermonuclear annihilation, that would definitely fix our need for fossil fuels for manufacturing and power issues for quite some time  Meh, time for this boomer to cook his lunch on his electric stove and then maybe go for a drive in my petrol car, for fun
    • It really helps that light duty vehicles have absolutely appalling average efficiency due to poor average load. Like 25% average brake thermal efficiency when peak is somewhere around 38% these days. So even a 60% BTE stationary natural gas plant + transmission and charging losses still doing much better with an EV than conventional ICE. And that's before we get into renewables or "low carbon nonrenewable" nuclear which makes it a no-brainer, basically. In commercial aircraft or heavy duty diesel pulling some ridiculous amount of weight across a continent the numbers are much more difficult to make work. I honestly think in 5-10 years we will still be seeing something like the Achates opposed piston diesels in most semi trucks running on a blend of renewable/biodiesel. Applications where the energy density of diesel is just too critical to compromise. CARB is running trials of those engines right now to evaluate in real world drayage ops, probably because they're noticing that the numbers just don't work for electrification unless our plan is to make glorified electric trains with high voltage wires running along every major highway and only a token amount of battery to make it 30 miles or something like that after detaching. Transport emissions is not insignificant especially in the US, but yes there's a lot of industrial processes that also need to be decarbonized. I agree the scale of the problem is pretty insane but EDF managed to generate ~360 TWh from their nuclear reactors last year and this is with decades of underinvestment after the initial big push in the 70s and 80s. I don't think the frame of reference should be solar-limited. France is not exactly a big country either. Maybe it doesn't work everywhere, but it doesn't have to either. We just can't live off of fracking forever and expect things to be ok.
