i'll also just say, I like your attitude, seriously. You were prepared to have a go at it...ok, f*ked it up, but, acknowledged your mistake and have learnt something in the process. As long as no major damage caused, not a bad result at all. Although, I you're seriously concerned bits of ceramic fell in the cylinder and you haven't run the car yet, pull out the plug and use a vacuum hard up against the hole, vacuum out any bits of insulator in there.
thanks, i already vacummed it after i pulled it out, there was some on the sides
Edited by IM-32-FK
im almost sure i got most of it out, maybe a couple of little pieces might of fell in. Would it just burn out when the oil warms up? Wont cause the engine to seize up or anything or reduce performance?
it's ceramic, it won't burn. Nothing good will come of having it in the cylinder. But, any household vacuum cleaner should be strong enough to pull bits out if you put it hard up against the open spark plug hole.
i vacummed it after i took it off and ran it through the hole too. Hopefully it wont do much damage. RB25de neo is not worth much anyway, if anything happens ill just put a rb25det, ive been meaning to do it for a while just saving up some cash. If it does f**k up, can i still sell the bottom end? like which part of the motor will f**k up, the head?
Pics of rb20 coilpack arrangement.
Notice how i had to cut the edge of the coilpack 2 and 3 with a angle grinder so they can sit in flat? One bolt on each hole mate...had to cut 4/6 of the coilpacks
Edited by IM-32-FK
Okay and where does the loom an igniter plug in?
to the stock rb20 clips. So the igniter has 2 large clips plugging into it, one from the loom the other is a clip from the firewall, the loom also has a grounding cable and another cable clip with 3 wires running into it which clips in to another clip on the firewall
Edited by IM-32-FK
Does this mean your sparkplug sale is off?? was really interested in buying dropped and over tightened spark plugs!!!!
More seriously, use a vacuum cleaner, some tape, and a 300mm of that clear 10mm plastic hose. Tape hose to vacuum cleaner hose and push through the spark plug hole and work it around while vacuuming. Not a guarantee, but its better than 'fingers crossed'.
    • I might have to shoot them an email. Pity the exchange rate is so bad at the moment. BTW, thanks for posting that table makes interesting reading.
    • Add these Sensors -Wideband, Oil Pressure, Fuel pressure, Intake air temp Good inspection of ignition system of coils, plugs and loom (12v feed and good ground)- a r35 kit is best bang for buck upgrade. A decent tuner should be able to see any issues with the trigger system- a link has good filtering but a good simple upgrade is the nz wiring bolt in kit. Check and replace all the fuel filters- you would be surprised at intank filter after a few years. Also good to check for any leaks on vac hoses and pipe work as has been said. No need to go overboard and spend big $$$ to enjoy the car. A quality tuner is getting harder to find as anyone with a laptop thinks they are a tuner. A link has great features to check sensor voltages and frequency inputs and easy to see live by pressing f12. The link can do a TPS & RPM fuel/ignition mapping on ITB cars then add a 4D table with MAP and ability to add a 5D to it (can help with economy at cruise with wheel speed vs TPS) Where are you located as that will help narrow down a good tuner ?
    • Reviving an old thread, I reckon my stagea is starting to slip. Car usually gets parked on a hill, narrow driveway so cant go up the driveway smoothly, anyhows, lately first gear feels "sluggish"? Not responsive. Feels like I gotta run the engine more than usual to get off the line...  Any recommendations for transmission servicing in Sydney? Or possibly just an excuse to go manual ?
    • Well, moulded carpets should fit well if the buck they use is the right shape. The finish is then just a case of stiching the trim around the edges. Shuoldn't be too hard to get it right. Back in the day, replacement carpets were all "fitted", in that they were stitched together, with cuts and slices taken out to make them form the shapes. Many more opportunities to get it wrong, hence all the concern over good vendors and bad vendors.
    • A timely blog via AASA (keeping in mind they sell brake fluid of course...) https://www.msbgarage.com/blog/news-and-blogs/brake-fluid-what-should-i-use/
