This thread is a train wreck. I approve.
Pics of RB20 coilpack setup.
Pics of compo received for the time (4 hours) it took to take maybe 10 bolts, some plugs and replace 6 spark plugs.
Edited by iruvyouskyrine
I bought a set of the same spark plugs just in 0.8 now it better fix it now i got a spare set of bcpr7es -11 if anyone want to buy $10 let me know only 100km used. Btw if this doesnt fix it im gonna link it hard
f**k YES i figured it out and it was the MOST STUPID REASON WHY!!! YOU WILL NEVER GUESS...
are you ready....?
ONE OF THE f**kING SPARK PLUGS WERE CRACKED INSIDE THE CHAMBER BECAUSE I MUST OF OVER TIGHTENED IT!!!
REALLY?? AND GUESS WHAT, as i was putting one of the new spark plugs in, I ALSO CRACKED ONE. So i put one of my old spark plugs from before i did the service back in. So tomorrow im gonna have to go buy one more spark plugs
f**k me im stupid, who would of thought tightening these spark plugs would make the white part crack??
seriously i wasted $50(coilpacks) + $60(coilpack loom) + $35(new set of spark plugs)+ the time spent travelling and the labour.
Learn this lesson from me, NEVER overtighten ANYTHING!
  • Like 1
You didnt crack it from overtighting it, you cracked it because you didnt hold the socket straight at some point while tightening.
If your holding the spark plug properly and tighten hard enough you will strip the threads in the head and the porcelain part will still be fine.
  • Like 2
this.
i was using the extension bar and it moves around the socket a bit. I got up to the third cylinder before i cracked it. I hope i didnt over tighten the first 2 cylinders...
a rubber insert in the long socket helps keep the spark plug central and will avoid cracking.
my god i have one with a rubber socket but i didnt use it, i think because the spark plug didnt go all the way in or it would get stuck in it.
When putting new plugs in, bottom the plug out in the hole by hand with a extension, then tighten 2/3 to 3/4 (max) of a turn extra.
So run them in till they reach the end, then tighten the last 2/3-3/4 turn more.
Just use your left hands fingers to keep the extension centered while the right hand turns the extension.
  • Like 1
man i feel so stupid because i even cracked one of the new ones and i think little bits of plastic fell inside the head....someone please call me stupid
because it would make me feel better :glare:
Stupid,stupid,stupid. You asked I delivered. Feel better now :)
  • Like 1
i'm pretty sure some awesome dude who knows heaps about european porn...I mean, cars...said
"spark plugs don't like being dropped. A cracked ceramic insulator can cause ignition issues"
spark plugs are one of the few things I use a torque wrench for, would suggest you do the same until you get the feel for them, or follow gtrpsi's guide above.
i'll also just say, I like your attitude, seriously. You were prepared to have a go at it...ok, f*ked it up, but, acknowledged your mistake and have learnt something in the process. As long as no major damage caused, not a bad result at all. Although, I you're seriously concerned bits of ceramic fell in the cylinder and you haven't run the car yet, pull out the plug and use a vacuum hard up against the hole, vacuum out any bits of insulator in there.
are you ready....?
Lesson is if it was fine before you touched it, then it's you.
It's always easier to blame everything else first though.
    • Agree with Rob. I recently did mine and replacing with a brand new unit made the most sense compared with rebuilding my existing gearbox.
    • Are you suggesting that the kit did a cheap and nasty job of just jamming the wheel in between other things and caused the misalignment? I mean, we normally do this with an integrated crank trigger wheel, not something bodged on. It's not 1995 any more.
    • I mean, given the number of BMWs you own their tolerance for improper torque is rather low. The number of torque + angle spec bolts and non-reusable bolts in one is nuts.
    • Atmospheric vent requires something that doesn't use a MAF for load. You would need a standalone ECU for that.
    • Hey all,   I’ve got an RB25 with a trigger kit that includes a crank wheel, and I’ve hit a wall trying to sort a timing belt tracking issue. The belt either rides right on the edge of the cam/crank pulleys or walks slightly forward once the engine starts. It tracks okay-ish for a moment, then creeps right to the edge—and honestly, it’s stressing me out.   I’ve spent hours removing and reinstalling the belt, double-checking everything:   Tensioner setup is good, checked multiple times Idler pulley and washers are all in the correct places Followed the RB25 timing procedure step-by-step     The only thing I changed was the rear crank washer—I swapped the OEM one for a Neato version, and it made things worse. The belt now sits even more forward than before. I’m beginning to think the crank trigger wheel itself (from the trigger kit) is the issue—poor design or slightly off dimensions.   What’s strange is that with the previous belt setup, it actually ran fine for a couple of years—around 4,000 to 5,000 miles, even with hard driving and high RPMs. But even then, the belt was always riding right on the edge, and I know that’s not ideal or safe long term.   At this point, I’m debating whether to:   Machine a few mm off the crank trigger wheel to bring it back in line, or Replace it entirely with a better-designed unit     Only thing is, I already have the Cherry Hall sensors, bracket, etc.—I just want to replace the wheel only, not the entire kit. Anyone know a brand or supplier that sells just the crank trigger wheel on its own?   Would really appreciate any feedback—especially from anyone who’s run into this exact issue and found a reliable fix.   Thanks in advance.
