Carbon Fibre Group Buy #3 R32 R33 R34 Etc *** New *** 10/25/2015
If they are real careful and promise to return mine, I could possibly let them have them to get the moulds. Id have to have royalties though for all the sets they sell lol
Aslong as the r33 twin gauge A pillar is a direct replacement, you can count me in for a FRP one in 52mm size holes.
Aswell as the r33 gtst s1 garage defend style radiator cooling panel please, can pay a 50% deposit for it all to be shipped to Darwin,0800.
Thanks,
Bronson.
wantgtr : i think it's a standard one let me find out if there is a full length one
32nsmo : they should be able to perhaps make you a set for free possibly lol
Bronno : yeah the A pillar is a direct replacement , did you want the r33 garage defend cooling panel in FRP or CF ?
Group Buy List
Longz : R34 Z tune front bar , R34 Wind Deflecter , R32 N1 boot spoiler ,
GCjosh : R33 GTS/GTST S1 Garage defend style radiator cooling panel
adz2332 : R32 GTST/GTR Top Secret Type 2 Style diffuser with fitting brackets Carbon Fibre
32NSMO : R32 GTR 2x N1 Boot Lip, R32 GTR 2x N1 Bonnet Lip , R32 GTR 1x OEM Front Grill
Bronno : R33 A pillar 52mm gauge FRP , R33 Garage Defend Cooling Panel
IcedTea : R32 N1 CF Boot lips
Hey interested in r32 cf items.
Cooling panel garage defend style full length if available and the cf abflug diffuser, if it's straight bolt onto oem lip.
wantgtr : attached a photo
sleeper_gtr : it should be full length not 100% sure ill find out and yes the AB flug is bolt on
Adrian : garage defend should be full length
32nsmo : FRP or CF spoiler ?
Group Buy List
32NSMO : R32 GTR 2x N1 Boot Lip, R32 GTR 2x N1 Bonnet Lip , R32 GTR 1x OEM Front Grill , 1x R32 GTR cf rear oem spoiler
Dobz : R33 GTR Jun Lip FR
sleeper_gtr : R32 Garage Defend Panel , Ab Flug Lip CF
Adrian P : S14 Garage Defend Panel
  • Like 1
Hi Longz
Do they have carbon fibre coilpack covers for the rb25det neo (r34)? If so how much
Also how much is the R34 GTT Dash Gauge 52mm, and do they have the centre console and gear surround in cf too?
Do you have pics of the R34 GTT \ GTR canards too please
Cheers
Hey Longz, I would like to put an order in for the following:
R34 GTR JUN High wing stands - $230
R34 GTT \ GTR canards 4 Pieces - $150
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
