So as I'm doing a bunch of work on the car, I thought I'd make sure it was e85 ready if I want to go that way in the future.
I currently have a teeny low pressure/high flow pump in the standard holder in the tank (nice and low) and a good old bosch 044 under a surge tank that sits under the rear sear outside the car. It's a great setup but AFAIK neither pump will survive if I run e85 through it.
What are people using for e85 safe lift pumps, and are there any external pumps similar in size to an 044 (so I don't have to stuff around with the setup too much)? I bought the big e85 walbro but it doesn't suit external use and is crazy big to use as the lift pump (who wants to warm and circulate that much fuel.....
Car only makes 310kw at high boost on e85 so it doesn't need 400kw+ pumps.
https://www.sau.com.au/forums/topic/460575-e85-lift-and-external-pumps/
A walbro 460 will fit with another Nissan cradle intank. (I have one in the 33, not sure what/if there is a difference in the 32 with the different fuel tank setup).
Have a look at the Holley dominator 1800 for an external.
A bit more work, it will work and is quiet.
Talk to Unigroup about the specific cradle to use
Walbro 255LPH 500HP External Fuel Pump GLS392 is ethanol rated
http://www.trademe.co.nz/motors/car-parts-accessories/performance/fuel-systems/auction-967861260.htm
According to NZEFI the Walbro in your tank (GSS341 and GSS342) is ethanol compatible ( I have run E10 though mine with no ill effects)
Check with Scotty - he will know and also has pumps at a good price.
My 255 twins are still going strong 6 years on in the Stagea, I guess I have proven they are long term safe. :P
I am using a peirberg in tank lift pump (part number 721.088.62) direct fit into cradle, e85/methanol safe, into a surge and a 044.
044 will be fine with e85.
Edited by R31 drift pig
  • Like 1
Flow rating of peirberg? (I know I'm lazy [emoji14])
200 LPH at free flow, 130 @ 3.5 psi. About half what a single 044 does at full noise - mine will be 280 lph @ 65-70 psi.
The 32 is different to the 33-34 setup, but that is the system I will be using once I purchase the 1800 dominator pump to replace my loud az fark Weldon pump, as I already have a Walbro 460 intank as a lift pump, was looking at Fuelab but have heard a few horror stories about them lately
Duncan, given it is the engine that primarily heats the fuel having a high flow intank lift pump circulating cool tank fuel through the surge tank can't be a bad thing, if the intank out flows the main pump then the engine return line can be plumbed back to the main tank so the surge tank is always full of the coolest fuel possible
  • 7 months later...
Hi, I have a nismo internal pump and a Bosch 044 external pump from a surge tank. I installed it after having fuel surge issues and it fixed them. I run e85 and am concerned about the longevity of the Bosch 044 pump.
I was wondering if it was possible to use the walbro e85 intank pump as an external pump as a replacement for the Bosch 044?
Edited by boxheadmr
I run the exact same setup on e85 in my track car for past 5 years and both pumps the nismo and 044 are still alive and have never had a issue with them yet.
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
    • Got just the wing painted and fitted up to the existing boot. Big visual change and about time after having a GTR wing sitting in the shed since 2018 Headed up to Mallala with a quick obligatory stop in at Boliver OTR Oil control mods seems to have worked. I checked the catch can after session 1 and there was a dribble of water/e85 with barely any oil in it. After session 2 and 3 there was almost nothing and I stopped checking after that. so either great success or catastrophic failure/block of the external breather The GTR wing made a noticeable difference in the 160-185km/h sweepers. It was a very hot day for the cars at over 33C but the previously done cooling upgrade/ducting/water sprayers meant I never saw over 60C intake, 105C water and 100C oil and temps would drop back down very quickly once I shut it down. AD09's are a decent tyre but certainly and expectedly a step down when compared the the CR-S/AR-1 I have had on the car for years of track days. The handling characteristics of my car which I often describe using the Tony Hawks Pro Skater balance mechanic where either side of the center is understeer/oversteer was much more pronounced with no "green/safe" zone in the middle. However, imo it steers well/easily during oversteer largely thanks to the custom ACOSTAL front end. Enjoy a loose lap POV with my mate giggling away as a passenger.   Group photo for Peer Pressure Racing made it back home and gave it a wash Overall a great success compared to my previous two track days where i cooked the Starlets motor and blew up the new diff in the R32
