Up for sale is my pride and joy. I've been the owner for 2.5 years and am the second owner of this car in Australia. I purchased it from an elder gentleman who imported the car back in 2006. He hunted for a few months until he came across this car. He found it to be one of the nicer examples he found in Japan due to the amount of optional Nismo extras the car had from the omori factory. It has been taken care of immaculately and gets the best of the best treatment every 5,000 kms.
The 110,000 service last week just had New Tyres, oil changed with Penrite HPR 10 full synthetic, both filters replaced, plugs, afm cleaned, brake and clutch fluid dumped and rebled with Bendix Ultimate Dot Fluid and new Euro wiper blades front and rear
Mechanically sound this car drives and handles great on the road.
Since I've owned the car I have done the timing belt, water pump and all belts, new coil packs and harness, new battery, rebuilt power steering pump ( which was not needed) New turbo and manifold gasket kit. Just the meticulous person I am. All parts used are genuine also
Exterior wise, the car is in great condition, washed every weekend and polished every month. The only reason I am selling as my partner and I are expecting our first child in a few months and I now need 4 doors.
It has never been raced, or thrashed down the quarter mile or around a race track!
I am not interested in trades, I am in no rush to sell either as I know this car is worth every $! First to see will buy 100%
The car is one of the tidiest red R34 GTT's in Sydney!
Specs are as follows:
Exterior
- Nismo LMGT4 wheels bronze wrapped in Michelin Pilot Sport 3 100% tread(brand new fitted last week) Also filled with Nitrogen.
- Nismo S Tune adjustable coil dampening suspension
-Nismo clear side indicators
- Nismo clear front indicators
- Red Rays engineering valve stems and caps
- Nismo 35 mm lug nuts with lug tool
- Cusco caster rods
- Whiteline sway bar
Interior.
- Bride bucket seats and bride rails all genuine not the cheap $400 knock offs - Easily $4000 of seats
- Head unit is a Clarion Dvd unit which pops in and out so it is well hidden, Sony 12" sub and speakers and amp
- Nismo carbon fiber gear knob
- Greddy Electronic Boost gauge and Fuel pressure gauge fitted to pillar.
-Greddy FATT turbo timer
- Genuine nismo gauges
- Alarm and immobilser
Engine.
- ARC Front mount intercooler - these are discontinued and are rare as they come!
- Walbro 255 Fuel Pump
-JJR dump pipe, full Kakimoto exhaust with high flow cat
- Cold air intake with 3A racing filter
- Turbosmart plumb back BOV
- Runs 0.8 bars of boost which is approx 11.5 psi
-Apexi SAFC 2 ecu which was tuned to 210 kw's
5 months rego left, Number plate is also included in the sale.. I have had people offer me $1500 plus for the plates but they just complete the car!
Price $19000 ONO
Located in Sydney - Inner west
Theres no doubt there is something I have missed so if you have any questions feel free to call or text me!
Cheers Pete
  • 3 weeks later...
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
