Up for sale is my pride and joy. I've been the owner for 2.5 years and am the second owner of this car in Australia. I purchased it from an elder gentleman who imported the car back in 2006. He hunted for a few months until he came across this car. He found it to be one of the nicer examples he found in Japan due to the amount of optional Nismo extras the car had from the omori factory. It has been taken care of immaculately and gets the best of the best treatment every 5,000 kms.
The 110,000 service last week just had New Tyres, oil changed with Penrite HPR 10 full synthetic, both filters replaced, plugs, afm cleaned, brake and clutch fluid dumped and rebled with Bendix Ultimate Dot Fluid and new Euro wiper blades front and rear
Mechanically sound this car drives and handles great on the road.
Since I've owned the car I have done the timing belt, water pump and all belts, new coil packs and harness, new battery, rebuilt power steering pump ( which was not needed) New turbo and manifold gasket kit. Just the meticulous person I am. All parts used are genuine also
Exterior wise, the car is in great condition, washed every weekend and polished every month. The only reason I am selling as my partner and I are expecting our first child in a few months and I now need 4 doors.
It has never been raced, or thrashed down the quarter mile or around a race track!
I am not interested in trades, I am in no rush to sell either as I know this car is worth every $! First to see will buy 100%
The car is one of the tidiest red R34 GTT's in Sydney!
Specs are as follows:
Exterior
- Nismo LMGT4 wheels bronze wrapped in Michelin Pilot Sport 3 100% tread(brand new fitted last week) Also filled with Nitrogen.
- Nismo S Tune adjustable coil dampening suspension
-Nismo clear side indicators
- Nismo clear front indicators
- Red Rays engineering valve stems and caps
- Nismo 35 mm lug nuts with lug tool
- Cusco caster rods
- Whiteline sway bar
Interior.
- Bride bucket seats and bride rails all genuine not the cheap $400 knock offs - Easily $4000 of seats
- Head unit is a Clarion Dvd unit which pops in and out so it is well hidden, Sony 12" sub and speakers and amp
- Nismo carbon fiber gear knob
- Greddy Electronic Boost gauge and Fuel pressure gauge fitted to pillar.
-Greddy FATT turbo timer
- Genuine nismo gauges
- Alarm and immobilser
Engine.
- ARC Front mount intercooler - these are discontinued and are rare as they come!
- Walbro 255 Fuel Pump
-JJR dump pipe, full Kakimoto exhaust with high flow cat
- Cold air intake with 3A racing filter
- Turbosmart plumb back BOV
- Runs 0.8 bars of boost which is approx 11.5 psi
-Apexi SAFC 2 ecu which was tuned to 210 kw's
5 months rego left, Number plate is also included in the sale.. I have had people offer me $1500 plus for the plates but they just complete the car!
Price $19000 ONO
Located in Sydney - Inner west
Theres no doubt there is something I have missed so if you have any questions feel free to call or text me!
Cheers Pete
  • 3 weeks later...
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 😂
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
    • also, we need to know which solution worked....
