Do you want an oil catch can or an oil-air separator?
An oil catch can vents to atmosphere (and therefore is 'technically' illegal), while the separator basically inserts into the crankcase ventilation system.
Both are there to prevent oil vapour getting into the induction stream (the oil vapour lowers the effective octane of the charge).
If you want a catch can, I have one that's designed to sit behind the battery in a R32 GTSt.
https://www.sau.com.au/forums/topic/4606-oil-catch-can/#findComment-71927
