R33 Gts-t Anti Roll Bar Link Bracket Snapping, Alternatives?
Hey All,
So my car has now snapped a 3rd anti roll bar link bracket, this time I didn't do it my mate did when he spun my car off the track.
Background:
Front ARB is a 24mm solid adjustable Whiteline product, currently set to 3/4 (stiffness) using new links..
ARB & links are fine, however it's the bracket that keeps on sheering off.
So what are the alternatives for R33s? I know S13/14/15 can be bolted directly to the control arm like what is provided by Whiteline (which removes the need to use the weak mounting point).
However look at the R33, there's no real way of accomplishing the same thing.
(reference sau.com.au)
I did do some searching on the net, however there weren't any real solutions to this issue I have.. probably the only option I have is going back OEM ARB and just get slightly stiffer front springs to achieve what I need.
le sigh :(
You're snapping the pressed steel bent up thingo stamped with an R in the photo, yeah?
If so, then your solution, in the absence of any better option, is to box up that bracket with some extra steel.
yep, and it only happens when there are heaps rapid oscillations such as running off the track lol.
I was hoping an off the shelf solution, similar to what I posted about how s chassis cars go about it.
I'd be surprised as i wiuldn't think it that common an issue. When i fitted my whiteline arb tho i had to flip the link over to get it to align with the mount & bar holes. To ask yhe obvious, you have done the same, and haven't really preloaded the link/bracket trying to get them aligned?
Factory brackets in some cases can tear out with upgraded bars. I know that the early Whiteline rear ARB's for EK civics were tearing the mounts out of the rear X-member. They had to develop a heavy X-member brace to address the problem. I heard of similar problems with Foresters when people started upgrading rear ARB's. These are only 2 examples of cars I've owned and looked at upgrading - could be a lot more out there that suffer the same fate.
Have you talked to Whiteline about this. They actually do take some accountability for this kind of thing.
Why don't you first stress releive the bracket by heating it to around 400c, then when you fit the bracket back on, put the bracket between two washers on either side before you bolt it back on. It should hopefully allow that tiny bit more flex, so it doesn't snap.
Just made that up on the spot based on the problem, but it should help your issue.
 Share
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on.
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
