Let's get together and run amok in Shepparton for the weekend as the last motorsport event of 2015 takes place.
Where: Courtyard Motor Inn
Address: 58-60 Wyndham St, Shepparton
When: Fri 11th & Sat 12th December
I've reserved the entire hotel, so you need to let me know which room you would like booked and I will put your name to it.
Dinner: TBA (group event out somewhere)
Rooms left:-
1 x Family (Queen & Bunks) - $130
1 x Deluxe Spa Room (Queen & Single) - $115
1 x Disabled Standard (Queen) - $115
2 x Standard (Queen & Single) - $115
3 x Deluxe Spa (Queen) - $100
3 x Standard (Queen) - $100
Entries coming soon................ :)
Rooms Booked:-
BOTH NIGHTS
Leon (Family Room)
Bec (Standard (Queen) - $100)
Campbell (Executive w/ Corner Spa (Queen) - $145)
Odie (Standard (Queen) - $100)
Wayne (Standard Queen - $100)
Jett (Queen + single - $115)
Jake (Deluxe Spa Queen - $100)
Myles (Deluxe Spa Queen - $100)
Russell ( 2 b/room family (R1 Queen, R2 Single & Bunks) - $155
Mark Ryan & Dano Standard (Queen & Single) - $115
Jeremey Barrell (Deluxe Spa Queen - $100)
Ryan (Standard (Queen) - $100)
FRI ONLY:-
Anna (Deluxe Spa Queen - $100)
SAT ONLY:-
Aaron Tan Standard (Queen & Single) - $115
Hi Guys,
Thanks to the above and others who have messaged me re accommodation.
I've only been home from overseas for a few days and the list is now updated.
Cheers for your patience.
NOW - get your entries in ASAP people :)
Bec
  • Like 2
Hi Guys - please note the list above is now current.
As there are so many rooms not taken, the hotel have taken control over the remaining rooms as of right now. They will be taking bookings from other groups, so I suggest you move quickly if you want a room.
If you need to make a booking, or if you need to alter an existing booking, you will need to contact the hotel directly:-
Brendan Magee,
Courtyard Motor Inn,
58-60 Wyndham St,
Shepparton 3630.
P: 03 5831 2355
F: 03 5831 2748
[email protected]
www.courtyardmotorinn.com.au
Thanks and see you all up there :)
    • Mostly likely welded. 'Coz it's f**ked. You have the car right there. Get someone to tap on the underside while you sit in the back with the seat out. You'll find it faster than we will.
    • Yeah, I'm pretty sure that's how it's going to end up. Mechanic suggested I cut a hole in the chassis/body to access the inside. I can cut the hole for access but will have to get someone else to help if any welding is needed afterwards. Things I'd like to know are: Assuming there's a captive nut inside, how's it fixed? And how can it be tightening but not fully loosening? If I cut a hole to access/replace a captive nut, is there a good place to cut for this one? Does it have to be at the side, or is there somewhere I can cut from above inside the car?
    • So i finally got the exhaust done. Full custom 3.5" stainless with dual tipped sp mufflers & a side exit aes dump valve.  Not as quiet on the outside as i thought it would be, but heaps quiter inside when driving and no more drone.  Some pics on Instagram
    • The wasteland, as least traditionally too, was the place with more relaxxed shittery/rules. Not to say you can post porn etc, but it was the place for good joking around, and a bit wild. There was also plenty of unwritten wasteland rules, such as what any user must do if someone posted up asking for likes/votes for a contest... Which was to go in and vote for someone else instead 😛
    • Plenty of people I knew who drifted set their cars up more for grip than traditional "drift", and then just added LOTS of power. Gave them more control, and bigger smoke shows.
