i got my r32 gtst about a year and half ago so a lot has been done to it so its quiet a large 1st post going through what it was like and what it is now witch is a forged rb25. when i got it was a stranded rb20det with a turbo back it had all the rust cut out and a gtr bumper modified to suit the gtst and had a full respray which was perfect at the time a untouched engine and a good body. it was fine for about 6 months until i went to the wakefield with mates and my turbo decided to blow. so here are some photos of when i got it and when my turbo blow up.
r32 bromance
greedy intercooler did a top job stoping it all from going into the engine
the exit hole from the explosion i was at around 7000 rpm when it went pop
so after i blew my turbo up i was planing on just replacing the turbo then i meet grub from imposible fabrication who ended up being a top fabricator and also a a fabricator who i could trust and didn't rip off and was full of great advice. so i ended up getting a high mount manifold made a new dump and modified intercooler piping all to suit the td0625g
slightly shorter piping that also didn't go over the hot side of the engine and in my eyes i thought looked a lot beta
so i had that set up for a while then the motor decided to blow in a tunnel when it was hitting gate hard :(:laugh2:
so the rb20 came out and i was going to drop in a rb25 and ended up forging the rb25 but while that was getting done i got board and made a vented bonnet,gtr wing,stereo install. and surge tank.
this is a stranded gtst bonnet cut folded and welded to make it like a gtr. im not a fabricator so i made it up as i went it turned out will i think'
this is the boot install i made it sounds nice and i can still fit the shopping
as a head unit i used a samsung tab 3 for some thing diffrent
im pretty happy with the out come i always believe you should try do it your self or you will never know what you can do
so i got all that done and while i was doing that i made a parts list and went and ordered all the stuff for the engine
os twin plate clutch
balanced and drilled crank
nitto oil pump
ross harmonic balancer
acl race bearings
nitto rods
cp pistons
arp head studs
tomei head gasket
super teck valve springs
tomei pon cams
hks timing gear
hks timing belt
hks fuel rail
sard fuel reg
turbonetics 7868 ceramic ball bearing
greedy look plenum (will be getting a real one soon)
head drain.
aem ems 2
aem cas disc
aem air temp
aem 3.5 bar map
aem wide band
there are some of the parts its not running yet it will soo the list goes on :wacko2:
the clutch got drilled and shaved for balancing
i was lucky to get to see the assembly of my motor
right not this is what it looks like in there
the most important part of any build is beer pizza and mates
thats just some of the stuff i have done to my skyline up until now there will be more to come
Edited by eb35aa
  • Like 5
https://www.sau.com.au/forums/topic/460607-ollys-r32/
GTR bonnets are alloy as you mentioned which means they are considerably lighter, but that obviously comes at a cost.. And if you don't really care about that then it's fine
With the GTR Bonnet the latch is positioned differently to make space for the front grille but you can work around that
I've seen and compared my GTR bonnet to Olly's Modified GTST bonnet and you honestly can't tell the difference until you try and lift it.. fantastic value if you ask me.. haha
  • Like 1
https://www.sau.com.au/forums/topic/460607-ollys-r32/#findComment-7626716
step by step in the fab section may be needed ;) Yer im only looking at it for the looks.
As said about how the latch was modded to fit the grill etc.
Did you have a gtr bonnet sitting there as reference?
https://www.sau.com.au/forums/topic/460607-ollys-r32/#findComment-7626723
I have a GTR bonnet and GTR bonnet latch on my GTST :)
https://www.sau.com.au/forums/topic/460607-ollys-r32/#findComment-7626733
Its impressive mate.....
What exactly is the diff between a GTR and GTST bonnet? Just the Lip part? apart from ones steel and ones Al
from what i know its just the lip i left around 35mm on the lip also dont do a straight line from edge to edge or it will look funny i followed the origanal curve of the gtst bonnet lip to give it shape and it looks good and im not running a n1 lip but if you run the n1 lip it will give you a good idear of that the lip shold look like and it also gives a good finish
  • Like 1
https://www.sau.com.au/forums/topic/460607-ollys-r32/#findComment-7626758
yeah i will see what i can do in the way of a step by step fab thread when i get home. you only need to trim the latch handel because it hangs out of the grill but i will see what i can do i have more photos at home of making the bonnet im just over seas so when i get home i ill make a fab post
https://www.sau.com.au/forums/topic/460607-ollys-r32/#findComment-7626816
That would be great mate!
As it looks the part and its nothing i contemplated doing before. but after seeing that dont see why not.
Plus run a N1 lip and any imperfections would be hidden!
https://www.sau.com.au/forums/topic/460607-ollys-r32/#findComment-7626839
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
