Hi guys i came across something wierd today building a rb25. I might be wrong here and wondering what you guys think. I have a block that was bored to 86.5 and i just bought a set of new cp pistons over sized for the bore. The machine shop had a piston so he could get the right clearance. The problem is the ring gaps look big like really big in the bore. The photos will show you guys what i mean. The gaps are like .064 in inch. Sorry my gauge isnt in mm. Damn yanks products. Lol
Im figuring that cp would have made it tight with room to adjust the gap.
https://www.sau.com.au/forums/topic/460636-ring-gaps-for-engine-builders/
Wow that is big, I don't reckon I'd use them. What is the recommended gap?? its usually more like 0.006"- 0.008" or 6 to 8 thou - yours is 10 times that.
On the bright side rings won't bind, no matter what the heat!!!
I have done the math and figure ill need 1.75 mm bigger ring with a 86.5mm bore. Wow wonder if thats avalible. I notice that the part nber from cp is cnp 3.406 thats the actual sizing of the rings. So if i was to add 1.75mm which is .060 inch the size i would get would be 3.466
Wonder how that will work. At that size ill need to gap them myself. Im planing on going with an end gap of .010 or so for occasionally hitting some NOS. max boost of 25psi.
My big problem is i cant find a chart for cp pistons and the ring gapping or size option. I feel stuck.
Does anyone one of a way to address this??
Yes. Right now i cant remember the actual size i got. I will update tomorrow. Work was super busy and will contact cp piaton tomorrow. Will they be able to supply the rings. Custom size i guess.??
I guess what Cef33y is wondering is....Was the bore machined to the correct size for the piston you are using??? Was it accidentally overbored??? Wouldn't be the first time.
Specs would give you the piston dimensions, clearances, and the recommended bore size.
  • Like 1
Hmm. I thought it may have been bored wrong as well. I was just to busy today to do anything. Ok here is where i must admit im a bit weak. Most likely because im just being lazy. I at the time did to blocks in miami florida with guess who some Australian guys. They do work for the coast guards here in the states. Son does the heads and dad does the blocks. May be an honest mistake. Im going to buy a dial bore gauge tomorrow and check his work. Guess what cp pistons can out and cp pistons went back in. By no means i think its there fault i actually think its just a different batch of pistons by cp and im just doing a rebuild now. Noticing the difference. Damn why do i feel its a money thing now. Well. Best solution if i was.to guess woyld be to buy 1mm or 40thow over pistons and rebore it as 1mm is my personal max i would go. Damn. But before jumping the gun ill contact cp and measures the bore and see what they have to say. From my personal experience i think a new set of pistons is in order. 1mm or 40thow.over. damn i cant believe all this bs. Ill take my caliper to work tomorrow and measure the block. They may have mest up.
Anyone can teach me how to check bore to piston clearance. Using a v caliper. Damn and its for a friend not even mine. :(:(:(
Thanks i have watched a couple of videos. Please look at the spec sheet that came with the piston is the piston to cylinder wall clearance what im pointing at. ??? If so thats small. I would opp to go with .004
Bore can be slightly bigger than suggested, .004" is fine.
Most cheap bore gauges wont distinguish between .0035" and .004" accurately. Get your machine shop to measure them in front of you at various points down the bore in the X and Y plane and note them.
Ring end gap depends on the boost and purpose of the engine, i wouldn't run .008" end gaps unless it was a very low boost tight daily driver.
If you turn up the boost and lay into it a bit aim for 16 to 20 thou with the latter based on serious power numbers.....60 thou, somethings not quite right.......
I'd put money on the bore size being too big for your pistons. I've never seen a set of CP rings that didn't need filing to get the gap right. You will probably find you have 12-16 thou at least, not 4.
Aftet i removed one piston took the rings off and insert it upside down to measure the difference from piston to cylinder wall clearance it seems to be close to 20 thou smaller. That would put me right about right if i use a 87mm bore piston but will never know. If the clearance is .004 and my caliper isnt to accurate when i wonder the caliper around in the bore i get like 86.9 thats very close to 87mm i feel the accuracy of the caliper is the problem maybe its a 87mm bore piston i need. Damn if thats the case thats a big mistake. Like a 1300 dollar mistake. Guess its better than assembling the motor to have it fail. Im glad i spot this. Im going to order a set of new pistons and rods and go from there.
Why do you need rods?
Pistons and rings I can understand.
This has the ring gaps you need for CP pistons and rings http://www.cp-carrillo.com/LinkClick.aspx?fileticket=LjC4jLmI4Ls%3D&tabid=74
They also recommend around 8 thou, but others may have better knowledge of it than manufacturers specs or me??
It makes no sense to me to just buy pistons. As i rather save som cash and stock up on pistons by buying the rods and pistion combination. Thats all. I know that pistons are cheaper.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
