Small update. Fitted some Cusco front camber arms today. Set them for max neg, should be around -2.5°.
I've had these for a long time but couldn't find a how to article. Turns out I spent more time looking for fitting instructions than how long it actually took to fit. Was done in under an hour. 3 bolts each side and boom, done.
I've got some Cusco tension rods to fit also and there is some whiteline rear camber arms and hicas lock bar in the mail. Will hopefully fit these during the week and get an alignment on Saturday.
  • Like 3
OHHHHHHHHHHH NO YOU DIDN'T [emoji20]
oh. btw.. SPOOLA R33 is for sale at $28k... runs 10s
That is a very nice car. I like the way he's gone about building it. But I'd rather build than buy. Also, its got a homo auto in it. May as well buy a Honda instead[emoji38]
Managed to fit a hicas lockbar the other day.91c5e3a0d32b64cfa36917d859855696.jpg
Get out. Lol.
Weight reduction[emoji3]
I know a hicas eliminator would have been better but this only took half an hour to do and since the ball joints are still in pretty good shape I went with this gktech lock bar.
I also fitted some Cusco tension rods. These where GTR items, I had them modded by the machinist at work. Needed to trim around 6mm of material off each crush tube end to accommodate for the gtst narrower bush width. The threads on the other end where the nuts go were extended to the bottom also. I also had 2mm machined off the lower lock nut to make sure I can get the castor angle I want. Lol. After all this they fit fine[emoji3]
I had these spacers machined up, so if ever decide to sell these they can still be used on a GTR. Wider market.
And fitted up
Plenty of castor[emoji3]
And a little neg camber.
  • Like 1
Just now, Count Grantleyish said:
Nice work Bill, finally gotten around to fit them hey?
Yep, finally. The tension rods needing to be modified had me procrastinating for a while. Thanks again for the cusco items. Ironically I also bought a set of whiteline rear camber arms exactly like the ones you where selling, waiting on those to arrive. So pretty much, i'll be running exactly the same arms you had in your car once upon a time.
As can be seen in the pics above, the drivers side swaybar link is leaning outwards and the passenger slightly inward, almost straight. I cant really slide the swaybar across any more to correct it,(maybe 2mm) as then i'll have clearance issues with the insides of the tyres scrubbing. I will revisit this after I have a wheel alignment done but can anyone see anything that appears out of the ordinary there with the swaybar install to cause that. Worse case scenario I can run some 5mm spacers on the front wheels to gain a bit of clearance but I'd rather not do that. Everything else on the front end there looks fine, I cant see anything that looks wrong.
22 minutes ago, Trex said:
Ironically i bought those rear whiteline arms, and just purchased some cusco front arms :P . I used whiteline tension rod bushes though.
Looking good mate!
Thanks Trex. I just removed whiteline tension bushes, Very ironic indeed. Lol.
That's a lot of movement. You may need some lateral locks or risk one of the endlinks snapping.
I personally have never had this amount of movement, or my bar possibly self corrects before stopping.
You can buy whiteline lateral locks which help minimize lateral movement.
The swaybar isn't moving under load, I've had to position it like that so that the tyre doesn't rub on it at full lock turning right. Something weird is going on there, just haven't had time to sit there and work it out.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
