I was also at Winton. Your car caught my eye, I was wondering where I had seen it before. Unfortunately I was having issues with mine for most of the day so I didn't get a chance to come up for a look and say g'day. I did however admire it each time I was lining up for the day. Congrats on the PB.
Thanks man, which car where you in?
perhaps make a splitter Bill, that would help so there's no need to reduce the ARB hardness
Did you say splitter, look what you've made me do now.
Splitter V1, 100mm overhang, made with 8mm marine ply bolted to the cross member, 10 rivnuts on bumper lip and 2 steel rods attached to rad support panel. I should block off the unecessary holes gaps but ill test it first and then make V2 out of a better material. Was hoping to test it at Sandown tomorrow but weather is not looking good, may have to wait.
Had some company as well.
  • Like 3
On 5/22/2018 at 7:49 AM, BrendanR33 said:
Whit R33 GTST.
Nice, what sort of dramas? From what i remember when watching the other groups your car looked pretty damn quick, unless that was another white skyline. How much power and what sort of mods are u running?
Edit, where did you get that pic from? Wondering if there was any of my boat.
I had a look through the sets of pics that were shared and you didn't really feature mate. See below, that was all I could see on a quick glance.
They are all on the AWDCC facebook page - https://www.facebook.com/groups/awdcc/
Brendan isn't much of a regular here so I'll answer for him. He had breather/oil control issues which, at its worse, was causing the car to misfire/stop making power all together. He ran his PB for the day of a 33 in the shootout despite having no power coming into turn 3, you could hear it die then come back.
He's got around 300rwkw, it's an RB25/30 with basic supporting mods.
Interesting that our lap times are almost identical given the power difference but same tyres. I think there was a few hundredths in it at most? Are you on 255 AR1 also or have I got you mixed up?
I don't have my RaceChrono phone here, but I can see you're a solid 20km/h faster down the main straight, and of course the other straights just not by as much, so I must be making up a little through each corner/under brakes.
I think there's a high 36 in these tyres with some clear track and on a good run.
Edited by ActionDan
Thanks for the pics @ActionDan I was on 265 Ar1. They had already done 5-6 track days before Winton. Still looked ok but obviously not at their peak. My car with me suited up and fuel in it is around 1500kg so id say yours would of been better under brakes for sure and would probably have held a few kph higher around the corners with the splitter and wing you have. Was having heaps of understeer, which im hoping the new splitter will fix and was driving cautiously considering the 300 odd km drive back home. There is definitely a few more seconds in the car if i push the limits with new tyres, i was quite slow around the sweeper, boobs and coming out of the chicane at the end of the front straight. Was only my 3rd time at Winton, 2nd with this car. i do want to go back again but sadly the distance means it won't be for a while. Overall quite happy with a 37 considering it's my daily driver and i drove it there and back. Only thing removed from it was backseats and different wheels tyres. Otherwise same spec as i drive it around in every day.
What tyres was Brendan on? What pressures did you end up with on the day on the AR1?
Yeah mine have done 4 days so far, 2 of which was in stinking hot summer and some portions are already down to the tread indicators and have been flat spotted from a brake balance issue I was chasing.
I'm really not sure how much the splitter helps tbh, but it looks the part. The rear wing definitely helped me but I got the biggest gains from roll centre adjusters/rear subframe and diff swap. Basically just better geometry.
Brendan is on the hankooks, what are they Z221 or something? Medium compound and still semis.
  • Like 1
Im hoping to get this out again to Sandown on the 10/6 if the weather is good to see what the splitter does for me, unfortunately will be on the same tyres as they still have plenty of tread and i like to get value for $, i'll run them till there absolutely shagged or times drop off significantly.
Bought a proper seat finally. Came home this avo to this package.
Current model Sparco pro 2000
Weighs in at 8.4kg, rail adds around 3.
Also bought these recently
Hopefully fit the seat over the weekend and give it a track test the following weekend.
  • Like 2
And installed
Ended up using a fixed rail similar to this i had laying around
Also recently changed my innovate mtxl wideband over to an AEM x series.
First impression is it's a little faster than the mtxl and i like how i can change from 3 to 4 decimals and between afr, lambda and 02% at the touch of a button unlike the mtxl which had to be changed through a pc.
  • Like 3
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
