Surprisingly RB30 is obtainable for non drug money. My hand may be forced, lol.
I completely stripped down the bottom end yesterday. Much carnage, no pics yet, take some tomorrow. The girdle was in 3 pieces, bits of block, rod, piston everywhere.
5 pistons and rods survived and are in great shape, ring lands all intact. A couple of bearings, I think it was towards the front showing some wear, otherwise the rest of it "was" looking pretty good considering the use and abuse it copped over the years.
Just remembered, the other day when I was at the engine shop and showed the builder the pics of the busted rod, his verdict was that it was definitely rod bolt failure.
  • Sad 1
1 hour ago, GTSBoy said:
but happiness should be the end result.
delayed gratification? lol...
  1. RB25DET NEO with headstuds, R33 ancillaries, manifolds and back in ~ 2 month job (given how fast @admS15 works)
  2. RB30DET + all the other bullshit involved, re-fab, etc. ~ 2 year job (because he's gone fk this, I'm over it)
  • Like 1
18 minutes ago, No Crust Racing said:
I'll just sit quietly and say nothing about timelines or engine rebuild projects...
same..... I was planning in/out new motor 2~3 months.. took 3 years and two motors to get a fully working car again LOL.
  • Haha 1
If some freakin idiot would actually sell me a half decent condition engine, this thing would be running next week. There are various engines for sale and various options that could eventuate if I could just get some sort of engine first. FML right now, lol
  • Like 1
I was doing a stock refresh on this 5cyl, then it got block mod shims and I bought a whole donor car to take all the performance bits of it... the "stage 3" tune is sitting on the handset waiting for the car to survive run in.
Always be upgrading...
  • Like 1
Everyone who is selling any form of RB right now seems to have the "I know what I got" attitude. I'm just about, out of options.
One guy pretty much doubled his asking price overnight.
At this point it seems like waiting 6 months (give or take a bit) for the bloke with the container coming from japland might be the best, almost only option.
The BMW and Ferrari options above are more straightforward than dealing with some of these farkwits.
  • Like 1
  • Sad 1
I did say it'll take awhile - This is why I put the V8 in, going through blocks like it's going out of style it became economical and far more modular going forward. It is after all a niche, Japan only car that arrived here in VERY limited numbers by people grey importing them.
An engine explosion in a RB is about a 1 year sentence on average, no matter what scenario you're actually in.
I repeat:
On 06/10/2023 at 10:46 AM, No Crust Racing said:
Send me what you want and I will put the call out on NCR if it helps.
Thanks Dan. I'm not that desperate yet but if anyone you know has any sort of RB25 in pretty much any condition from complete running to rebuildable rotating assembly let me know. RB25DET is preferable but I'll consider anything that a solid engine can be built from.
There is always the contact GTSboy gave me in Adelaide, not looking interstate yet as shipping can be a pain. Hmm,  I should contact him anyway.
Your around Albury aren't you? I could drive there and back if you manage to find something.
I've PM'd a few contacts and just chucked in on the NCR user profile, you can watch the post and see if anything comes of it.
If my mates turn up something I will let you know, they are usually pretty good at coming back to me quickly.
  • Thanks 1
On 10/5/2023 at 1:41 PM, No Crust Racing said:
Must be nice to have a fully working car after 3yrs...
I can't relate.
If I take his 3 years, and add another 9 years... I'd be still a touch shy of mine...
Also, I do have an EJ255 and STi 6 speed... I'm sure somehow we can fit it between the chassis rails... 😛 ya know, for lower CG up front :P
Plus, STi parts, then you can tell people how car modding really is an infectious disease... :P
  • Sad 1
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
