Turns out the swaybar problem was due to excessive toe at the front. 8.4mm in total. Has now been fixed and there is plenty of clearance for the sway bar. Wheel alignment was done this morning but I had to bring the car back because rear tyres where scrubbing. Getting some more neg camber dialled in. Will update later with final settings.
Final alignment settings.
Front
Castor 8°
Camber -2.25°
Toe out 0.8mm each
Rear
Camber -2°
(tried -1.25° first but tyres rubbed on wheel arch) -2 ° is as straight as I can go. I think I can live with that.
Toe in 1.8mm each.
Car feels good. Turn in is very sharp with 8° of castor. Hopefully I'll get to test it out on the track in a couple of weeks time.
  • Like 1
  • 3 weeks later...
Went to Winton on the weekend. It was the first time the 33 has been there and so far it hadn't been quicker than my S15. Saturday was the day that changed. Smashed my s15 time by 5.5 seconds. Yeah baby.
My driving was not the best, was struggling to get the car pulled up and set it up for corner entries but im very happy with the overall time. There is definitely room for improvement with driving and car setup.
  • 3 weeks later...
Minor update. Killed the brakes at Winton a few weeks back. I had qfm a1rm on the front and hpx on the back. The fronts where on the indicator and the backs on metal, oops[emoji3]. I am now going to run the intima Sr all round. Hopefully they're a bit better.
I had some new rotors in storage but decided to sell the fronts so I can get some 324mm discs with calliper adaptors instead and i used the rears I had. I grabbed some hfm adaptors for the front and they bolted straight on without any grinding or other modification other than reshaping the stone shields. I have left them in place because I plan to run some ducting in the future, so I'll just cut a hole in them and run the piping onto/through them.
5bd4464df3fb05f9aa1d0e483926db6f.jpg back
  • Like 1
Looks solid mate!
Hope you like the pads [emoji4]
Thanks Johnny. Pads are good so far. No squealing at all and good bite especially once they have a little heat in them. 3 weeks from now they'll get a good work out at sandown and I'll write a proper review of them after that. If they're no good, I'll send the lebs out for your blood[emoji12]
  • Like 1
@Dose pipe Sutututu can you check if intima Sr is available in dB 1346. Apparently it will move the material of the pads in around 5mm so it doesn't hang over the edge of the disc and use more surface area. Let me know your findings. Cheers.
On 9/7/2016 at 9:21 AM, admS15 said:
Minor update. Killed the brakes at Winton a few weeks back. I had qfm a1rm on the front and hpx on the back. The fronts where on the indicator and the backs on metal, oopsemoji3.png. I am now going to run the intima Sr all round. Hopefully they're a bit better.
Looking good! I was just checking out the HFM adaptors the other day - let us know how they go on the track, might be a decent budget upgrade for me as well.
EDIT: What's the manufacture quality of the adaptors like, do they feel solid enough?
  • Like 1
Thanks man. I will let you know how they go, but in your case you already have 310mm GTT brakes so going to 324mm isn't really much. It won't do much for me either, just a bit more rotor to absorb and disperse heat. If i was you, I would be concentrating your efforts on ducting (i should follow my own advice here) and some half decent pads. You may eventually have to bite the bullet once you wear out your semis and upgrade to 18" wheels, then you will have heaps of options. I will probably end up doing something more serious if I'm forced too. If only we could shed a few hundred kg off our cars, brakes wouldn't be such am issue. LOL.
  • Like 1
The quality is actually pretty decent, i was worried that I would have to grind some of the calliper for clearance as I had read some older reviews saying but I didn't have to, so maybe hfm revised them. I have used their adaptors before on the back of my S15 and they proved to be fine and held together well. They are about the only thing out of the whole hfm catalogue that is any good.
  • Like 1
their old adaptors required grinding of the caliper itself.. which IMO is super silly.. looks like they've updated
About time that mob got something right.
Made a nice little change to the bov you're gonna be proud of Johnny. Got a blanking plug for the trumpet side of it, coz chooo sounds are gay. So now it's either plumb back or full dose. Sutututututututuuu, dose for weeks[emoji3]
I've been going insane for ages with boost control issues. I've checked everything I could think of numerous times and finally got to the bottom of it. Damn mac valve. I used to get full boost b4 3.5k and then I lost about 3-400 rpm in response. A few weeks back I threw on a turbotech mbc and the response was back. I proceeded to eBay and ordered a new Mac valve. Today this arrived and was fitted.
I did have issues with this earlier on with a wire coming off it but I soldered it back on. Not sure if the issue was related to a bad connection with the wire or just wear and tare of the internals of the valve.
Went for a quick test drive afterwards and logged this on my nifty little android app. Full boost again before 3.5k. The full log of that pull says 18psi at 3400. Happy as with that.
It's handy this app. Its designed to be used as a racedash. It has shift lights and you can customise what it displays. It also logs a heap of parameters. Another bonus is its also got an ethanol content gauge.
Gotta love android[emoji3]
I permanently use my old retired phone to run this app.
Edit. Dose has also increased. Doses haaaaardddd[emoji1]
    • Same.  It's depressing to say this but the skyline can go months on the charger between drives.
    • I often leave mine connected weeks at a time. The main one I use is the old model of this, it has 2 important features - choose battery chemistry other than lead acid (most of mine are AGM) - power supply mode which you can use to try and recover dead flat batteries as "smart" chargers often don't recognise a dead flat battery is connected https://www.projecta.com.au/products/IC10/intellicharge-10a-bat-chgr The Ctek I  use was meant to have a battery test mode as well but it doesn't work 100% of the time so I am pissed at them. The distributor did everything possible to make warranty and support difficult so I'll stay away in future. The main thing with a "trickle" charger is it has multi stage programs, ie once the battery is full it turns the current right down to just maintain the charge....in the old days we just used real "trickle" chargers for that which had a maximum output of say 500mA which was safe to just leave connected to dumb old lead batteries.
    • I've heard people claim with Just Cars (now defunct) and have been paid out, but painful process, and with Shannons, but noone I know or heard of has claimed with Enthusiast, hence I'm a bit nervous with their policy. Sure I'm "covered" but am I? is the real question
    • I have the Century CC1206 12V 1/3/6Amp 9 Stage Battery Charger. It is different from the one you linked but I don't know in what way. Their manual says that it both can be left on 24/7 and that it shouldn't be left on 24/7. Go figure ¯\_(ツ)_/¯ I haven't been game to leave it on there for more than 2 days.
    • I don't read the 2nd paragraph the same way, I believe it is defining "modifications" from the previous paragraph, and I'd be happy to have a lawyer argue that in case of an issue.....if they have agreed to it and listed it on the schedule it is covered. Has anyone had them attempt to deny it based on that reading?
