Now the car drives awesome. Traction is an issue with the shitty falken 265's that are on at the moment. I am contemplating doing an e85 flex tune. Trent reckons another 40 odd rwkw is achievable. All I have to do is get a bigger fuel pump and rewire it with a relay, add a flex sensor and tune for the e85. Some days I really feel like doing it, other days not so much. What are peoples opinions on flex fuel?
Melbourne weather has been shit so far today. So waxing with collonite is on the backburner but I managed to sort my traction issues this morning. Got a set of Achilles 123s tyres fitted. 265/35/18 all round. I know there's much better tyres around but @ $150 fitted each I couldn't go past them. If anyone wants any, import monster has a limited supply at this price. First impression driving home in monsoon like weather is that they're pretty good in the wet. No unwanted wheelspin unlike the falkens that came off. I was 4 wheel drifting around corners this morning without trying to. I will update about the performance of the 123s as I drive on them.
^Thanks dude. Wideband sensor is on the front pipe just in front of the cat, I'm still running the OEM one in the factory position and that gets used while the wideband warms up or fails. I'm not running an air sensor ATM which apparently is a big no no but the AFR seems to be fine whether its cold or hot but I will be installing 1 soon just in case. Im thinking of putting it in the crossover pipe just b4 the throttle body.
Bit of an update, Dropped the front end about an inch or so yesterday. Looks heaps better, although another inch lower would be great. Made it up the driveway at work ok, just got to see if I can get out this afternoon without destroying my front bar. Fingers crossed. If all goes well I may try lowering it a touch more and then adjust the rear to suit. Here's a couple of crappy pics. The Achilles 123s tyres seem to be doing very well in wet or dry. Really have to punch it hard to break traction in the dry. Only negative is they are noisy farkers. The collinite wax is doing it's job awesomely as well, the water is beading off the paint like water off a ducks back and the paint still looks clean after the water has dried :smile:
Managed to crawl out of the driveway at work with only a minor scrape. I'll try and refine my exit strategy tomorrow and hopefully I can make it out with out scraping so then I can lower the front some moreB)
Talk to a good tuner and see what he says about afr gauges...
I've heard and seen nothing but crap from them, they are not even close to the same readings on a dyno unless you get a very high end unit from haltech for example...
The $260 odd dollar ones are not accurate and I've seen a few cars go bang because of this, owners believing the gauge over the dyno.
Josh
    • Nah, you failed to pay your washer cover subscription and BMW have revoked your access.
    • Haha thanks Lith,  So it's currently working quite well and the torque reduction is setup and working phenomenal. It also got a custom torque convertor from All Fast in WA. Stall speed somewhere around 5500rpm unlocked but still with the lockup. The car went back onto the dyno after a 3yr hiatus (even with the dbw, and other mods completed in this time) managed to make ~515kw at all 4 hubs. Sean setup the Torque reduction which now sounds awesome and working well. We setup adjustable torque controlled launch control aswell.  Man what a feature. Especially when drag racing on street tyres I Managed to get out to the drags late last year and tick a huge bucket list item off of running mine and the cars first 9. Car went a 9.98 @142 Still had the young fellas car seat in the back aswell.  This was on 255/40/17 Nankang AR-1.  Currently the Turbolamik is still completing it's own torque calcs and managing shift times from there. Unfortunately emtrons can export is still a little restrictive to export the ecu calculated torque just yet but I have recently been suggested a work around that I just haven't had a chance to trial yet.
    • Yeah its bad eh. Ey! Watch your mouth. Yep, spot on. The rear's are always gone too though from brake checking. I had them perilously close to a tree that we had taken down. I think the tree peeps may have taken it. Either for a trophy, or accidentally.
    • f**kin' yikes! That insulation is the shittest stuff I have ever seen. You need to do an insurance job on that f**ker, pronto. WRT to the washer cover, I would have said that there'd have to be some at a wrecker, then remembered that it's a BMW, and reasoned that every single wrecked one would have been tailgating and so the front end would be trashed.
