On 26/09/2023 at 6:05 PM, PranK said:
Dang, that's shit. 7-8 years is good, but still shit. :(
I'm super keen to see where this goes tho, theres some good banter in here already and I'm in for the ride.
Could always swap it out for a BMW N54. Duncan love these.
I could just buy a BMW M2 comp instead and be done with. I know @Dose Pipe Sutututu will approve.
  • Like 1
  • Thanks 1
100%
I regret building mine, I always seem to make wrong financial & illogical decisions in my life.
2 hours ago, PranK said:
....Could always swap it out for a BMW N54. Duncan love these.
Actually, good idea.
To paraphrase the 200B joke, the N54 has 1 less design flaw than the N55
  • Haha 2
And the head, looks like 2 intake valves got bent and a bit of a dent on the edge of the chamber. Should be repairable if I can get my hands on a couple of valves.
Dent at edge of chamber
Rest of the engine components looked good. Definitely less cross hatching in the cylinders than last time it was open. Surprisingly, from what I could see of the crank through the vacant no. 5 the journal didn't look that bad, there's more damage on the counterweight. The crank will be scrap but I expected to see more significant damage.
On the hunt for 2 intake valves so I can get the head repaired, if anyone knows anyone with a couple to spare, please let me know.
I wonder if the turbo letting go the first time was a warning sign the motor was going to let go.
As in bits of motor came out and knocked the turbine.
Hopefully @GTSBoy's RB hoarder mate has things for you!
If not, I know of a guy with a built RB25DET NEO that's keen to sell his motor, also comes with a complete running R33 with A/C, subwoofer, new window tint, added sound deadening, etc. Lol.
  • Haha 2
Possibly but don't think it's related as it looks like the rod definitely let go before any bit of piston did, turbo survived this time. How about a straight swap? I know what I've got..
On 27/09/2023 at 11:45 PM, Kinkstaah said:
Why would he buy that specific RB25DET NEO when he can buy the solution to constantly exploding RB25DET Neos... with similar extras?
Unfortunately LS doesn't align with the K.I.S.S method
On 28/09/2023 at 7:30 AM, No Crust Racing said:
Sorry to see that mate, hope the repair goes well, are you  DIYing it?
Thanks Dan. Engine building an RB is not something I think I can do to the level required. So the only DIY will be limited to installing an engine or properly repaired head on a good block.
On 28/09/2023 at 9:02 AM, Duncan said:
Yeah that's not going to buff out. How is they bore where the rod failed, any grooves you can catch with a fingernail?
Surprisingly other than the viewing window, the bore looks great. There is one gouge that you can feel. Im pretty sure I created that when trying to get the piston out with a crow bar😂
23 minutes ago, Duncan said:
JB Weld and go again
21 minutes ago, admS15 said:
You know any suppliers that sell it by the bucket?
A rather extreme form of block grouting?
And ironically - yes. We have an epoxy supplier that I buy buckets of different sorts of epoxies from, for various purposes. You kinda have to open a vein though.
Edited by GTSBoy
  • Haha 1
Get it machined and I imagine you could do the work to rebuild it yourself if you wanted to, but I'm saying that after having invested a lot of hours and a few bucks in in learning and having just started a fresh build that didn't blow up (just pisses out oil from new front and rear mains lololol).
Send it to NCR and I'll build it for you cheap as but you get zero warranty lol
Edited by No Crust Racing
  • Like 1
May have to open an account
On 28/09/2023 at 9:58 AM, r32-25t said:
I’m amazed at how well that head has come out of it. Worst case is open the chamber up and build a off tap rb30 for it
Me too, rb25/30 would be nice but then would have to upgrade everything are it. Turbo, injectors etc. are all too small.
On 28/09/2023 at 10:25 AM, Dose Pipe Sutututu said:
I still would buy that RB25DE NEO for cheap(?) and keep it spare OR use it :)
I am seriously considering this route, trying to arrange to go have a look at this particular motor.
The problem with this scenario is that the bulk of the $ is in the machining and parts. Wouldn't be saving all that much by assembling it but the chance of me messing it up would be too great.
I'll send you the windowed block to practice on, 😂
Options so far in the pipeline
Cheap rb25de neo
Disassembled RB25DET NEO minus head, good condition. Reasonable $ but apparently pending. He's going to let me know if the buyer doesn't turn up. Idea here was to rebuild with correct forged pistons and put my head on it. Would be a good fresh motor. It's unlikely though.
Good running RB25DET. Prices unreasonable so far.
The joke was Dose was attempting to sell his complete car, and I joined in too.
My gut feeling is to tell you to actually go RB30 if you get the head cleaned up. Never turn down an upgrade opportunity when something breaks... it makes it more bearable 😛
  • Haha 2
    • Convert to dual filament bulb   FWIW, it will look odd - I dare say a bit dumb as it looks like your flasher relay has shit the bed.
    • If the RB29 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
