On 08/11/2023 at 3:06 PM, Komdotkom said:
Make a basic slide hammer out of a bit of all thread the plugs are not that tight (which always surprises me).
What size all thread are we talking here. It be pretty thin wouldn't it?
Anyway, valves have arrived from both partsouq and amayama. Also got a nifty adjustable tapered ring compressor cheap off eBay, looks like it's been used once
Still waiting on the rods, meant to be here in the next hour according to auspost. Considering the torrential rain that just started, I reckon the posty will probably hold it for tomorrow or drop back at the post office.
  • Like 1
Be careful with that type of ring compressor they are known to snap rings.
Single size tapered ring compressor from someone like is a better option but obviously only suits one bore size.
Go slow, lots of lube, just generally good advice..
Dang, it's company 23 brand. Meant for subarus. Seems like the tools made for them are about as good as the cars, sti's excluded. I bought that one as I though being tapered I wouldn't have to knock the piston down. It's only adjustable from like 78 -86.8mm. if the ring ends aren't in the 10mm of open gap I can't see how it's going to be an issue. Anyway, I'll be careful and treat it like a virgin. Plenty of lube, proceed with caution.
Rods have been delivered, I'm not home ATM to check them out. Will do later.
Valve guides you mean. Well I don't have a definitive answer but now that I have the valves in my possession, going to visit the local supplier that has listings for rb25 guides and work out if any are suitable. If not, I'm stuck. May have to ring Nissan and see if they have stock and how far I have to bend over..
  • Like 1
Just spent some time this morning weighing up the rods on some super accurate scales at work. Pretty damn good. They're advertised as being within a gram of each other. They where much better than that at around 0.3 of a gram. Not bedh. They're close to 80 grams lighter each than stock too.
Preliminary measurements of the bores of the big and little ends are spot on using the internal mic. I'm getting really good with using those now, can get accurate measurements quicker. I'm hoping to use the bore dial on them a bit later to confirm my measurements and roundness a bit better.
  • Like 4
That's awesome!
My piston/rod assemblies were up to 8g out of balance, machine shop said 3g is nice for a street engine on stock components so I balanced them down to 1g because I'm an idiot who thought spending literally 10hrs on that was a good idea...
  • Like 1
  • Haha 1
I haven't weighed the piston assemblies yet, watch this space.
What are people's thoughts on how to select which weights go where? Pair 2 that are closest in weight and run them as matched pairs?  I was thinking of doing that and putting the 2 heaviest in the middle. Don't know how I came up with that.
Probably wouldn't matter 1 bit but I'm here and would only take a minute to arrange.
See what the total weight is for a given piston/rod assembly, including rings/pins/bearing shells, rod bolts.
If you can just move parts around to get them all within 1g for a total assembly or so you are golden.
If not, move them around such that the weight differences are minimal vs everything else, I.E don't put all your lightest things together on one piston/rod assembly as now you need to bring everything down.
"Best" way is watch matching each component and adjusting as necessary, I only went as far as doing rods/pistons individually as the variance between ring sets/rod bolts/and shells was miniscule on a 3 decimal scale. Also using a rod weighing assembly so big and small end can be reviewed separately as there's more to it than just total weight.
New forged rods will be basically spot on for this purpose, it'll only be the pistons that might need attention. Cast pistons usually vary a little, just depends on the batch, if you have to remove material you do it VERY gradually around the pin boss (where the gudgeon goes through) on the inside, do not touch the crown/skirts etc - lots of videos online.
I'm waiting to see if a few 7k rpm trips blows a piston up from stress risers...
  • Like 1
Hmm. This is making me want to unnecessarily rebuild my engine.
  • Haha 3
20 minutes ago, admS15 said:
Hey @PranK is something funny going on in the forum. New posts don't seem to be showing for me. I only see posts from like a week ago. Is it just me?
Nah, it's borked. Depends on what you mean by "new posts don't show". I see new posts, but the latest posts page isn't working, and other issues. There's 2 reports of this in the feedback forum.
Re valve guides. I have a freaking headache. Been down the rabbit hole trying to work out what's what. Nissan wants 65 each for intake (in stock) 85 for exh (import from jap)
I read an old SAU thread where CA18 guides where used for intake on an rb25 and had to be trimmed down 2mm as slightly too long.
I found this in the fsm
If I'm reading that correctly, the only difference between the in and exh valves for the purpose of the guides is 2mm in shaft length and a minute diameter difference of shaft which will be accounted for with reaming.
So I'm thinking the CA guides should work. The exhaust should fit straight in and the inlet trimmed 2mm.
I've come across nason guides part numbers
PVG9019 10.03mm OD 5.994 ID 40.005 length listed as CA18 and RB25DE/DET
Also PVG9018 same ID and OD but 42.926 length. Listed only for CA18.
I believe PVG9019 should work or do I buy 2 of each? I know the best bet would be to get the old ones removed and measured but I'd rather give the shop all the bits and pieces so they don't have to stop half way and wait for parts. I've got an even bigger headache now. Going to get some Panadol.
  • Like 1
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
    • I remembered wrong, but was close though 1Kz setting because those Jaycar SSRs don't go any faster, 1x pump per SSR with flyback diodes & heatsinks. In saying that, the heatsinks are overkill. Just on an alloy plate is more than sufficient. You'll find without a flyback diode, your SSRs will heat up big time and also die prematurely.  I've been running the two same SSRs since the last motor, no issues, car does 2 hour straight drives in summer once in a while and gets punished on the track. Nothing melts, no hot messes, etc.
    • Hmm. You're probably best off working out what the lobe centreline or even the LSA is for the stock cams, with VCT OFF. That's bound to be out there somewhere. Then, work on the assumption that the Kelford centreline is probably the same, and wouldn't be more than a couple of degrees away, if it is different at all. I'm very surprised that you needed to adjust the exhaust cam by 5° to get it on spec. That screams there's another problem somewhere. Anything from the belt being 1 tooth off (how many degrees is one tooth worth?) to simple user/measurement error on the degree wheel. I say this because Kelford, like most quality cam manufacturers these days, does a pretty good job of actually making the cams to spec, not relying on patching it up afterwards like we had to do back in the 80s.
    • Besides packing it, you can also fill your pump through the oil filter inlet port. After cranking for what felt like an eternity without pressure, i fed a tube in through there and filled it with oil. Cranked for a few seconds after that and had pressure.
