16 minutes ago, MBS206 said:
Driving on the weekend, air con on full blast, opened a window as dog wanted to get smashed in the face with bugs.
No difference in temp, may as well drop all the windows and run full flow air!
Obviously these guys live further south in cooler climates where AC continues to operate 😛
I'm down south. It seldom gets hotter anywhere else in the southern cities than it does in Adelaide. When we get 40°C, it's usually for a week at a time. My aircon works, and works well. I just don't need/want it in most circumstances. Even driving home from work in the afternoon for 45 minutes, where the air over the road might be 45°C, I prefer the windows down.
In fact, I use it so seldomly that I needed to get it regassed because it all leaked out somewhere and we couldn't find where, and I really should use it every week to keep the seals wet....but I always forget. It's probably been 2 months since I last remembered to turn it on.
I use AC every time I drive the car. Something* makes the car pretty warm simply by existing. It's how I know the car is truly up to temp, water temp, oil temp, cabin temp.
That said it'll be ~22 and keep the temp down on a 40 degree day. There's no excuse for the deletion of aircon. Ever!
  • Like 2
No. It's all Aluminium! :p. And that's the point I'm making, I wouldn't have done it if I couldn't retain AC!
I recently drove it with the center console out, I had thought it was gearbox heat. However after driving it for about an hour, the shifter was still cold and all the heat shielding from the tunnel was working great.
I now think it's the fact that there's headers running behind the steering wheel/infront/underthe driver, and the fact you can feel your ankles warmed when you step out of the car seems to suggest that too.
In any case yeah. Aircon sure is great.
  • Like 2
I seem to recall my VT2 SS with LS1 6 speed getting freaking hot around g/box on long drives. Always assumed it was the box but thinking about it now, there was pacemaker headers either side of it going into twin cats. Greg your assessment of where the heat coming from, sounds about right.
I've got a 10L one, love it.
Also have the basic SCA parts washer, that mostly sits there as an extra work surface but is very handy when needed.
Edited by No Crust Racing
willing to swap your A/C setup for 2 x window switches?
  • Haha 2
10 hours ago, MBS206 said:
So to slightly less de-rail this thread, and bring it back to an earlier, slightly more on topic discussion, Look at what the algorithm is pushing at me...
f**king algorithms...
I'm not willing to click on any unlabelled external link; but I assume it is a hand held device intended to replace a wife
  • Haha 1
Heh. It might be worth it. I turned it on last night because the thunderstorm was causing fogging inside the car. I don't think the compressor came on, meaning that the gas has probably made an exit somewhere. f**ken.
  • Haha 2
Now imagine you had working AC, higher quality of life.
It's safe, I didn't hide it in the quote of someone else :P
it was a link to a Facebook video, advertising Vevor 10L ultrasonic cleaner, and they cleaned 6 pistons while still on their rods in it.
Been driving the 33 to work past couple of days, have clocked up 350km and decided to change the oil and filter. Going to run some cheap mineral oil for the next thousand KMs. Got some nulon 15w 40 premium mineral oil for cheap off eBay. $28 delivered. It arrived today. Looks like Fastway can actually deliver unlike couriers no thanks.
Break in oil came out looking very clean as one would expect. I cut the filter open and was happy to not find any traces off stuff that shouldn't be there. New filter was fitted and oil filled. Noticed a small coolant drip past couple of days, was coming from lower rad hose clamp. Gave it a little more tension, all good again.
Went for another little drive in the arvo, pretty close to 400km done so far. Haven't thrashed it's tits off quite yet, maybe after another 200km.
  • Like 5
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
