Project MU aren't that noisy..
if..
shims are clean
shims have that anti squeal shit
rotors are perfectly flat
I recently installed 350Z Brembos, they don't come with shims OEM.. can't wait to drive on them.. will be squeal city. Lucky Project MU sell the shim kit for 350Z and R34 Brembos.
Nothing positive. Chasing a boost leak ATM. The turbo isn't holding boost the way it used to in the top end anymore. It used to hold 17.5-18psi and is currently only holding 14-15psi. It will make full boost with a pod but not with the airbox back on. Used to be fine with airbox. I will be removing the upper intake manifold this weekend hopefully to replace that gasket and check all those little hoses down there. I will update with my findings.
This is the same findings I had with my factory airbox, Pod filter on its fine. Everyone said the factory box is shit. Could be just a dirty filter though, no? My panel filter is filthy too
Filter is clean. Apexi panel, I have also tested with a BMC and k and n I have laying around. Same result. There is something else going on with my car because I never had an issue with holding boost before with the stock airbox. I'm suspecting the upper intake manifold gasket which I haven't had time to replace yet. Obviously the pod filter does flow slightly better than and unmodified stock air box and therefore is allowing the turbo to hold boost better although there is a problem somewhere. I find the sound of the pod to be hideous and annoying. Air box is my preference, just gotta track down the source of my issue.
If you take the plenum off check the two half's are flat and not warped, my R33 plenum had a bow in it and a new gasket was not enough to seal it, and tightening the bolts too tight makes it crack, lesson learnt here..
Edited by AngryRB
Get someone to smoke test it. At least that will stop you replacing things that is not broken
I want to replace that gasket as a maintenance thing. They do tend to fail on 25's and its a 20 year old part now so I might as well do it. Its not a 26 so I don't need 300 hours to take the plenum apart[emoji12]
Thanks for the heads up. I'll check it with a straight edge when I finally get around to doing the job.
I may have found my problem. I blocked the bov off, just to rule it out and since it was quick and easy to do. Boost is now building up quicker, faster, harder and is holding up top perfectly. Just got to put the airbox back on and verify. If its all good then I will have to decide wether I continue driving around like a full hectic uleh, doseing and fluttering everywhere or getting a new bov.
get longer FMIC piping LOL... add additional longer sections for no reason
I might make some piping to go all the way to the back of the car and then do a 180 and come back. Ya reckon that'll do the trick[emoji1] lol.
10 points right there, time for some chap laps!
Remember to slightly hold the brakes down for maximum dose
  • Like 1
    • I don't really know general street pads too well, but there is no reason you can't get a low dust, long wearing, no squeal pad that works for those calipers at a reasonable price....they would just be a low end to medium price daily style pad.  If new pads don't have much bite or they loose it over time, it is probably just the pad glazing up which you can fix by giving them a good thrashing every now and then (or get the mechanic to deglaze them at next service) Track or semi track pads are where you have to put up with excessive dust (and potentially squealing as a side effect of that) in return for good bite and performance when very hot. Street pads have nothing like that sort of punishment, even long downhills with the brakes on are easier than a track session
    • lol yeah I'll check that, reminds me of the LDV thread!  I don't think that is the problem here, the starter doesn't even solenoid click. I did do a super quick test by removing the starter motor's power cable from the engine bay fuse box and the battery voltage was still 10v, so something super fishy is going on. BTW here is a R33 fuse box table I threw together from a few sources....use at own risk! R33 Fuse Box and Sources.xlsx
    • Johnny's approach, throw all the Nissan electronics into the trash. Best thing I've done to my shit box, go DBW.
    • Sounds like the JAX guys must have installed some really awful pads, are they BenShit/BenDicks pads by any chance?
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
