Hi all i have a R33 gtst auto at the moment i have about 170 rwkw the mods are safc2, GFB Stealth blow off value, Blitz sbc boost controler, 3inch exaust & a blitz front mount intercooler it is running 11 psi at the moment and i am wanting about 200 rwkw so if some one could suggest some mods that would get me around the 200 rkwk area. I dont realy wanna spend thousands either but open to sugestions
Would cam gears do the job or would i be looking at a new turbo then if i buy a new turbo would i have to get bigger injectors and fuel pump or is there something else i could do well thanks for ya help
https://www.sau.com.au/forums/topic/46067-need-help-reaching-200rwkw/
  • Replies 69
bigger intake and outlet for the turbo
eg dump pipe 3' and metal pipe replacement(thats just my suggestion as mine is starting to collapse), stage 2 shift clutch so the trans can handle the power ya putting through
GTR pump and computer you should easily be there if not it'll likely be arounf the 220rwkw
Hi all thanks for ya help i might try getting a dump pipe from some where and trying the fuel pump. i have heard i might be able to get a uni chip installed but then i would have to take my blitz boost controler off has anyone else have a uni chip are these good ?
fuel pump, adjustable fuel regulator, dump pipe, hi-flow cat, bump boost up to 12-14psi (ran my stock turbo on 1bar for round 2 years an still was in good condition when removed for the upgrade), pod filter. all that should get you to 200kW+
as far as unichip, i think its only an option for R32's, havent heard much about them.
to be honest, havent really researched into it as far as the AUTO bit goes being I have a manual, surely theres a powerFC with the auto option, or a Microtech or the new Wolf 3D?
there are plenty of high powered R33 auto's out there, an I'm sure they cant be running on a stock computer. Send all the ECU manufacturers an email and find out, thats what I'd do.
or start a new thread on R33 AUTO AFTERMARKET ECU'S?
What ECU do you suggest, keeping in mind that it's an auto?
Nope manual only for Skylines
or a Microtech
Nope
or the new Wolf 3D
Close, but still has gearshift quality problems and gearbox durability is questionable.
Waste of time, they tell you they will, and then when you find they don't, try getting your money back?
The only true HIGH powered ones I have seen have "non electronic" autos (Raceglides etc).
Yep that's been done a heap of times, no one has a GOOD ecu yet. There are a few that are close, but no cigar.
Then why did you tell MR R33 GTST to get an ECU, when there isn't one? He spelled it out in the first sentence of his opening post
Sorry, that last one was a bit harsh :P
Next time your down in Adelaide give me a PM. My auto works fine and has been tuned at Tillbroks and MorPower. Admittedly I am not running huge power yet (only 200rwkw) but I havnt taken the plunge on a new turbo yet.
Are you still running the standard ecu to control the ignition for the gearchanges?
We are racing at Malala in late August, maybe try it then?
no- I just pulled the standard ecu and replaced it with the PFC - no problems.
I have been told by others many times that this wont work because a friend of a friend knows someone that heard that this wont work, but my argument is "look at mine, no problems and it all works well - including the gear changes.
I have a wolf3d in my auto skyline and its getting dyno tuned tomorrow........the gear changes arent that bad but it does hold the gears a bit longer and 1-2 is a little more jerky. I have read on this forum that if i run 2 wires from the wolf3d loom to the auto ecu and tap into the TPS and tacho wires it will shift fine.
I have been searching for a wiring diagram for the auto r33 ecu but i cant find one, so i dont know which wires to tap into......if anyone has the diagram ill be able to try this and know for sure.
But.........
Since it is designed for a manual, the Power FC has no provision for retarding the ignition on gearchanges. In fact it doesn't even know that there are gear changes, since it has no programming to talk/listen to the auto ecu. Unless you lift your foot, this means that you get full power (torque) during the gearchange. This is not good for smooth changes and it is very harsh on the auto. The most wear occurs on the slippage during gearchanges, having full power then is not so good. ;)
This is not "friend of a friend" stuff, plus I have tried a number of times to get it to work with quite a few ECU's. Always the same problem, jerky shifts and flaring on the change. We saw a 40 degree increase in gearbox oil temp in a 20 minute drive as a result. Plus it get worse very quickly, over 200 rwkw and I reckon I could kill a gearbox in a week. :wassup:
It's not like you plug the PFC in and the engine won't run, that's simply not the case. It runs perfectly fine and can be tuned just the same as a manual. It is the interface to the auto that is the problem.
Maybe it's time for some more research, I will be talking to Tillbrooks tomorrow, I might as well ask some deep and meaningful questions. :rofl:
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
