Hi all i have a R33 gtst auto at the moment i have about 170 rwkw the mods are safc2, GFB Stealth blow off value, Blitz sbc boost controler, 3inch exaust & a blitz front mount intercooler it is running 11 psi at the moment and i am wanting about 200 rwkw so if some one could suggest some mods that would get me around the 200 rkwk area. I dont realy wanna spend thousands either but open to sugestions
Would cam gears do the job or would i be looking at a new turbo then if i buy a new turbo would i have to get bigger injectors and fuel pump or is there something else i could do well thanks for ya help
https://www.sau.com.au/forums/topic/46067-need-help-reaching-200rwkw/
  • Replies 69
bigger intake and outlet for the turbo
eg dump pipe 3' and metal pipe replacement(thats just my suggestion as mine is starting to collapse), stage 2 shift clutch so the trans can handle the power ya putting through
GTR pump and computer you should easily be there if not it'll likely be arounf the 220rwkw
Hi all thanks for ya help i might try getting a dump pipe from some where and trying the fuel pump. i have heard i might be able to get a uni chip installed but then i would have to take my blitz boost controler off has anyone else have a uni chip are these good ?
fuel pump, adjustable fuel regulator, dump pipe, hi-flow cat, bump boost up to 12-14psi (ran my stock turbo on 1bar for round 2 years an still was in good condition when removed for the upgrade), pod filter. all that should get you to 200kW+
as far as unichip, i think its only an option for R32's, havent heard much about them.
to be honest, havent really researched into it as far as the AUTO bit goes being I have a manual, surely theres a powerFC with the auto option, or a Microtech or the new Wolf 3D?
there are plenty of high powered R33 auto's out there, an I'm sure they cant be running on a stock computer. Send all the ECU manufacturers an email and find out, thats what I'd do.
or start a new thread on R33 AUTO AFTERMARKET ECU'S?
What ECU do you suggest, keeping in mind that it's an auto?
Nope manual only for Skylines
or a Microtech
Nope
or the new Wolf 3D
Close, but still has gearshift quality problems and gearbox durability is questionable.
Waste of time, they tell you they will, and then when you find they don't, try getting your money back?
The only true HIGH powered ones I have seen have "non electronic" autos (Raceglides etc).
Yep that's been done a heap of times, no one has a GOOD ecu yet. There are a few that are close, but no cigar.
Then why did you tell MR R33 GTST to get an ECU, when there isn't one? He spelled it out in the first sentence of his opening post
Sorry, that last one was a bit harsh :P
Next time your down in Adelaide give me a PM. My auto works fine and has been tuned at Tillbroks and MorPower. Admittedly I am not running huge power yet (only 200rwkw) but I havnt taken the plunge on a new turbo yet.
Are you still running the standard ecu to control the ignition for the gearchanges?
We are racing at Malala in late August, maybe try it then?
no- I just pulled the standard ecu and replaced it with the PFC - no problems.
I have been told by others many times that this wont work because a friend of a friend knows someone that heard that this wont work, but my argument is "look at mine, no problems and it all works well - including the gear changes.
I have a wolf3d in my auto skyline and its getting dyno tuned tomorrow........the gear changes arent that bad but it does hold the gears a bit longer and 1-2 is a little more jerky. I have read on this forum that if i run 2 wires from the wolf3d loom to the auto ecu and tap into the TPS and tacho wires it will shift fine.
I have been searching for a wiring diagram for the auto r33 ecu but i cant find one, so i dont know which wires to tap into......if anyone has the diagram ill be able to try this and know for sure.
But.........
Since it is designed for a manual, the Power FC has no provision for retarding the ignition on gearchanges. In fact it doesn't even know that there are gear changes, since it has no programming to talk/listen to the auto ecu. Unless you lift your foot, this means that you get full power (torque) during the gearchange. This is not good for smooth changes and it is very harsh on the auto. The most wear occurs on the slippage during gearchanges, having full power then is not so good. ;)
This is not "friend of a friend" stuff, plus I have tried a number of times to get it to work with quite a few ECU's. Always the same problem, jerky shifts and flaring on the change. We saw a 40 degree increase in gearbox oil temp in a 20 minute drive as a result. Plus it get worse very quickly, over 200 rwkw and I reckon I could kill a gearbox in a week. :wassup:
It's not like you plug the PFC in and the engine won't run, that's simply not the case. It runs perfectly fine and can be tuned just the same as a manual. It is the interface to the auto that is the problem.
Maybe it's time for some more research, I will be talking to Tillbrooks tomorrow, I might as well ask some deep and meaningful questions. :rofl:
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
    • @KinkstaahKrinkle paint the "silver" alloy, not the red filter frame Engine bay heat won't be a issue worth worrying about as the silver alloy blocks it off on 3 sides, as for the top, the bonnet seals most of it and the big OEM CAI intake snorkel is still fitted in its original position  I will head into Clark's Rubber when I have some time to grab some pinch weld to tidy up the alloy after I paint it As for performance, I honestly wasn't expecting any, the only reason I got it is because the intake noise sounds cool to my old ears when I'm feeding it the beans Sometimes it's the silly things you do in in life that gives the most fun, and I do love anything that makes cool car noises In other news: I survived 4 nights at sea with Jackie not throwing me over board, holidays are continuing now as we are currently chilling at the Beachcomber in Toukley, after taking the coast roads from Sydney in the MX5, top down all the way, Toukley is where I spent a good deal of my youth holidaying during the summer months, there's lots of reminiscing going on,  and lots of beaches and old houses to visit Next on the list is to head to Batemans Bay for a few days, but we will take the Commodore out to stretch its legs, then Commodore hasn't really moved for months
    • There’s probably people who’d like to do it and then when it comes to putting their hands in their pockets they’ll all disappear into the shadows
