ROBO you got it in one its an upgrade clutch kit for the auto good for around 230-250rwkw
i blew my last auto 6 months after i bought the car, well i didn't blow just wore out the top two gear clutches, happens with auto once ya starting putting more power through it, the box gets weaker, so when i put a new gearbox in i replaced the clutches
i was gonna change to manual, but was $3500 was the best quote at the time found it for $2500 now, but i put another auto in and it cost me around $900 with everything thats including buying the box so i thought that was the best option, 2nd gear is wicked now under full throttle i pull it side ways for a good 1-2 secs if i don't change properly IE i drive it like a manual thats just me
  • Replies 69
You won't get much with a cam gear, maybe 5rwkw!!  I hardly could pick the difference.
I noticed a difference! At the drags im breaking traction in the top of first gear when I launch which I wasn't before the Ex Cam Gear. I'm over it now tho and wanting that next mod :)
A cam gear will cost you about ~$160-180 delivered from Nengun/Greenline. Along with about 1.5hrs of workshop time and its a great cheap mod for less than $300.
Take a look:
i noticed the grunt increased mid-range and it seemed to have a lot more go.. its worthwhile doing.. and for the price especially. Seemed to idle a bit rougher after that, but that may have been the new tune. Unfortunately I didn't get a dyno read out to quantify anything in any proper terms.
hahaa.. its a bit like that.. i got over the whole car, sold it, and now to build a fast one :)
obviously not anything ground breaking, but I just got my PowerFC installed and tuned and i am making 200 at the wheels at 1 bar - this is with 3" turbo back exhaust, ebc, FMIC, air POD and PowerFC. Injectors will be at limit now, so next up for engine stuff will be turbo+injectors+cam gear/shafts.
Its good insurance at anything around 200rwkw to replace the std factory pump (it could be getting a bit tired) and also to add a rising rate regulator to screw a few more kw out of the std injectors.
Remember if only one injector is struggling, (and this may not show up on your dyno analysis) and you are too close to 100% duty cycle, it could easily cost you an engine rebuild.
Hey there
Ive got an auto 96 series II that registered 273.6hp(203rwKw) at 11psi on shout-out mode
probably done more mods than some, cause I dont want to change the turbo or standard ECU
Trust MX cat-back
SS highflow cat
RSR front pipe with stock dump pipe
Apexi filter
TRUST V-SPL intercooler kit
SAFC-II
Greddy Profec B EBC
HKS 256 exhaust cam with cam gears
Bosch 910 external pump mounted inline without surge tank and malapassi FPR waiting to go in
Apexi boost gauge and TOYO RA-1 as well to complete the list
probably will buy a manifold, dump, and intake pipe later and see how much more power the standard turbo can make
good luck with your car though
Hey there
Trust MX cat-back
SS highflow cat
Apexi filter
SAFC-II
Greddy Profec B EBC
That's a very interesting approach, it proves that there is more than one way to skin a cat. Do you have progressive dyno results that you can post? I would really like to understand what makes up the increases. :cheers:
sorry SK, only did one dyno so far and I sorta put everything in reverse order,
EBC first, then SAFC, then FMIC, exhaust and cam last before finally going on dyno
from what I can tell the FMIC felt to make the most difference. I'll post my dyno sheet up soon.
Dont have the funds to change ECU or turbo so I thought I'll do everything else and see whats the maximum safe limit of the standard turbo
Im wondering about the auto trans though, should I start worrying about it?
To answer the questions about the unichip. I have one of these on my manual GTST and they work great. I haven't had any issues with it and I'm making 190RWK at 14psi with the standard turbo. I don't understand why you were told that u couldn't run an EBC with the unichip because that isn't true. I'm running a turbosmart E-boost. The unichip can control the boost if you want it to, however it should only be an option so you should be able to retain the Blitz EBC that you already have installed.
I'm not sure if you can get one for an auto though.....
well every one i have come to a bit of a stop in reaching 200rwkw i took my car along to a dyno day on saturday and it start to ping at 170kw at 6200 rpm boosted at 11psi. now could someone please tell me what this could be could it be injectors and fuel pump or more as yous all know its auto so its a bit hard to get a good ecu. so now i have the problem finding out what it could be so if any of yous have had this problem please let me know what yous have done to fix it well thanks for all ya help and i soon hope to reach 200rwkws after this minor hold up !
Usually this is ignition timing related, but it is easy to tell if it was fuel related via the A/F ratios. If it was going lean then it will detonate. So, did you get an A/F ratio printout from the dyno day? If you did, it will be easy to tell whether it was ignition of fuel. :D
nah didn't get any a/f readings on the print out because it was power runs only i might take it back this week and get it dynoed the other time i had it dynoed it was on 12.5 the whole way so i dunno if it could changed i aint sure so i will take it and see if its not the a/f how can i fix this ?
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
