I am very skeptical about dyno readings.
194 for those sorts of mods sounds a little unbelievable.
On a dyno Dynamics dyno, I got 142 at 8 PSI and I had a full exhaust installed.
My mate that owns the dyno said that they can make the readout what ever they want.. So if a non-honest mechanic wants to rip you off, he can do some mods, and make it dyno higher so you think he has done well.
The Stock ECU (even chipped ) and stock turbo are not capable of making anymore than 160rwkw - 180rwkw max.. (180 max is being generous)
  • Replies 69
Dyno readings dont mean shit, as your dodgy mechanic example points out. Anyone chasing a power figure is missing the point IMO.
On a Dyno Logic I recorded 153rwkw. The ONLY difference yesterday was the addition of a high flow cat and the fact it was recorded on a Dyno Dynamics. 40rwkw from a high flow cat? I dont think so.
I'd like to know why a chipped ECU (believe it or not, a chip makes a fu(kin big difference) teamed with a stock turbo cannot make more than 180rwkw.
You see my point.
As for the second part of your post. My friend had one of these "chipped" ECU's, and also had a 550HP turbo bolted onto a custom manifold (that he made) and a full 4inch Stainless exhaust which he also made himself. This car had a custom intake system (Dual R33 Throttle bodies) and this car made around the 220 mark.
A little while after, the motor blew up because of this "chip"
Be very careful son.
  • 9 years later...
Hey guys, I recently got an R33 GTST which is 100% stock and I want to get around 200rwkw just so its got a bit more power but I want it reliable, what sort of mods should I get, and what sort of price range would I be looking at? Cheers
Edited by speeddemon778
Drive it a bit longer - drive another Skyline with 300kw (which can be made reliably) and see if you will still be happy with 200kw. Then settle on a figure and save for the mods! See the turbo upgrade threads at the top of this page to see what you need for the various power goals.
Or if you're on a budget and never really want more than 200kw, just get your stock ECU socketed and chipped with Toshi's map. It's optimised for AU 98RON and the afrs have been tidied up. Save that 1000$ on a tune and that 1000$+ on an ECU
You'll yield close too 200kW if not more depending on the health of your motor
Cheers guys, im just setting 200rwkw as a sort of basemark and maybe progress from there if i decide i want more, im looking at maybe $4k-6k to begin with but will that get me much at all? Im pretty new to imports ect i grew up around old school V8's and all
    • Hi All,    I have my BW EFR 8474 with a T4 split 1.05 rear housing. Rear housing is ceramic coated and drilled and tapped for EMAP take off.  Supported 520awkw at 35psi through the 8HP with ~5k rpm spare on the BW 127k limit. Ran a 9.98.    Turbo is one of the first that was released but only done ~3k kms.    Asking $2800 happy to negotiate. Only selling to upgrade.   Located Gladstone QLD happy to ship.
    • Hi is the Toshiba sceeen still available?
    • Just wondering how come the hood was grinded down?
    • I have no hard data to report, but I have to say, having driven it to work and back all week, mostly on wet roads (and therefore mostly not able to contemplate anything too outrageous anywhere)..... it is real good. I turned the boost controller on, with duty cycle set to 10% (which may not be enough to actually increase the boost), and the start boost set to 15 psi. That should keep the gate unpressurised until at least 15 psi. And rolling at 80 in 5th, which is 2050 rpm, going to WOT sees the MAP go +ve very quickly and it has >5 psi by the time it hits 90 km/h. That's still <2.5k rpm, so I think it's actually doing really well. (I edited this from a previous version where I stated 80km/h was <2000, but that was a false memory. If I am rolling at ~1700 in 5th and floor it, it will start making boost before it goes over 2k - which is a separate "experiment" leading to the same conclusion. Which is that the boost threshold is actually quite low. It's not fast there, obviously, but it certainly makes progress towards going fast, which is not what it's been like for a long while!!) Because of all the not-quite-ideal things that have been in place since the turbo first went on, it felt laggy. It's actually not. The response appears to be as good as you could hope for with a highflow.
    • Or just put in a 1JZ, and sell me the NEO head 😎
