Hi all joined up here the other day in the hope someone might be able to help me with a tricky electrical problem. I recently had to replace the altinator on my pathfinder 1992 wd21 Z24 , after doing this the alt warning light would not go out , since then I have replaced the following : battery , fuseabile links , the fuse between the altinator and the battery &all earth leads . But the alt warning light still remains on. My volt meter shows 14.5 volts @1200 rim ? Can anyone help? Thanks
https://www.sau.com.au/forums/topic/460685-wd21-pathfinder/
